Switching from a chrysler typr electronic ignition to a pro-comp setup and get zero spark at the coil. All wire connections are correct. Changed coil...no difference. Connected the 12 volt red to the battery...neg to battery...other pickup red to ignition key on...distributor wires proper...orange wire to the coil and black to coil..blue ignition wire to coil...hooked another distributor to system and all's it does is make electronic noises when turned...still no spark at coil wire...going to change the box tomorrow...Keyed voltage on pickup wire is around 10.6 volts....goes to coil...is this proper?? also connected wires that were connected to ballast...as it's no longer a player. do have over 12 volts to power the box from the battery..all wires have good continuity..Thanks in advnce to any/all help...Thanks moparts
