Too fast for pinks?
#461887
09/07/09 02:37 PM
09/07/09 02:37 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
A bit of a dilemna. Last time out, after removing the exhaust and putting the extensions on (how it was dynoed) I discovered it likes to shift higher without the exhaust. Moving the 1-2 shift point from 6500 to 7000 resulted in a 10.006. I dialed the shift point back to 6800 and went 10.11 (lifted, probably would've been a 10.03 or so based on the 1/8 et), 10.03 and 10.05 on the next three runs. Air at fontana was junk. I expect air to be at least a little better at Famoso, and am concerned I'll be dipping into the nines running it without the exhaust. Will they boot me if I'm running hi 9.9's without license, diaper, net, chassis cert, pants, collar, etc? Should I put the exhaust back on and just plan to run 10 teens, or maybe some hi 10.0's?
Re: Too fast for pinks?
[Re: G_bob]
#461889
09/07/09 02:41 PM
09/07/09 02:41 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I was on that 9.99/10 flat fence a few years ago, I just ran it all out and seen where I was at. If it went 10.04 or so I was fine, if it went 9.98 or so and they smacked me on my wrist I would short shift it the rest of the day. The best thing to do is have your license and all the proper safety stuff but I usually barely have enough spare money to even make it to the track.
[Re: ProSport]
#461890
09/07/09 03:45 PM
09/07/09 03:45 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
One guy in a late model Mustang got kicked because he was going high nines witout the proper certs and a competitor ratted him out... The have to comply with a set of safety standards to run at the tracks and I think it mirrors NHRA's Put them mufflers on there and join our 10 second crew...
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#461891
09/07/09 07:53 PM
09/07/09 07:53 PM
G_bob
Riverside, Ca
That was my concern. I'd love to get that 9 second slip, but don't want to risk being booted for lack of equipment. I think they look at all four of the runs (two on friday, and then the two on saturday) and eliminate those with big discrepancies between the times. A 9, followed by three 10's (from short-shifting) seems like it would be a big red flag for a sand-bagger. And as they majorly emphasize the "all out" aspect, that would also be a sure way to get kicked out of the field.
[Re: Lil Demon]
#461893
09/07/09 10:00 PM
09/07/09 10:00 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
GBob - if friday is a TNT - those runs will not be looked at by the PAO crew. They will get your two Sat runs only.
That may not be so true.... I made only one 10 second run and it was on Friday.. Yet the floating was 10.98
[Re: Quicksilver440]
#461895
09/08/09 12:57 AM
09/08/09 12:57 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
"Pinks" has a tech procedure, but the car will still likely be looked at by the track, so it depends on how strict the track is. Certain tracks are notoriously strict. At Atlanta for example, does not matter if it is NHRA, NMRA, ORSCA, PINKS, ADRL, whatever, the track guys look at the car, and it better be right, or you don't go down the track.
Monte
[Re: The Shadow]
#461899
09/08/09 09:18 AM
09/08/09 09:18 AM
Posts: 501 Port Mcneill,B.C.Canada
Islandcuda
pinks tech at seattle was a aaa breeze to say the least, my biggest worry would of been a competiter ratting you out, people change when it comes to money. I don,t think the pinks people care one bit as long as it,s all out, tim
67 cuda new best 1.395 60 10.240 at 128.58mph
[Re: Islandcuda]
#461900
09/09/09 11:25 PM
09/09/09 11:25 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Glenn, I ran 53 9 second, and 2 8 second runs, before I finally broke down and got my license, and made everything legal. Some Tracks I'd get talked to right away, others, never a word. You have to pick your spots, and IMO Pinks all out wouldn't be the best time to step it up!!
In fact, the Pinks All Out at Firebird a few years ago, was the reason I finally did get legal.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
