PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? #460846
09/06/09 05:53 PM
09/06/09 05:53 PM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
I was just reading a post AL ALGUIRE had put up and he was talking about putting his trans cooler at the rear of his car. I have almost no space at the front of my Duster because of the CSR waterpump, aluminum radiator and electric fan. It is almost too tight of a squeeze to put the transcooler with the electric fan that is mounted to it on the front side of the radiator. Will the trans cooler cool good mounted back toward the rear of the car? Who has tried this? Anyone got pictures?
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: mopars rule] #460847
09/06/09 06:54 PM
09/06/09 06:54 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
The cooler doesn't know if its in front or back of the car. Its happy as long as there is cool air moving through it, front or rear! If you think you have a spot in the back for it, great. Keep in mind you want to protect the cooler from debris, so not behind the rear tires,
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: ProStDodge] #460848
09/06/09 08:13 PM
09/06/09 08:13 PM
alabama
mopar addict
mopar addict
alabama
Anyone got any pics of theirs mounted toward the rear of the car?
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: mopars rule] #460849
09/06/09 08:19 PM
09/06/09 08:19 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
A buddy of mine has one of those finned Moroso heat sink types mounted next to the trans under the car.
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: mopars rule] #460850
09/06/09 08:25 PM
09/06/09 08:25 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
can't help with a pic tonite..but i run a cooler mounted half way back on the car(probably half way down the door.)..it's a Moroso cooler part #41200..i mounted it on the frame connector and ran the line from there..could get a pic tomorrow if your interested..
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: racerAL] #460851
09/06/09 08:45 PM
09/06/09 08:45 PM
alabama
mopar addict
mopar addict
alabama
I would definitely be interested in a picture. It is a good size cooler.
The part number through summit racing is:
PRM-12311
I tried to make the part # a link but was not successful, if anyone else can link it I would appreciate it.
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: racerAL] #460852
09/06/09 08:46 PM
09/06/09 08:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have a fan on my trans cooler. It is just simply bolted between the frame rails in the rear.
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: mopars rule] #460853
09/06/09 08:47 PM
09/06/09 08:47 PM
Mine is a finned heat exchanger. I mounted it to my tranny crossmember. I have a tube chassis and I can drop the tranny (727) with the crossmember/ heat exchanger still plumbed to the tranny. No fuss, no messes. I don't have a tranny guage but the fluid is checked everypass. I run8.55 @ 154
Very pleased with this setup.
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: Al_Alguire] #460854
09/06/09 08:49 PM
09/06/09 08:49 PM
alabama
mopar addict
mopar addict
alabama
AL, is the fan on top or bottom of the cooler?
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: Al_Alguire] #460855
09/06/09 09:04 PM
09/06/09 09:04 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Here ya go......... link to the pic'... (looks big,,,and has a fan ? )
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: mopars rule] #460856
09/06/09 09:11 PM
09/06/09 09:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Here is a crappy picture..Dont mind the ugliness going on it is just mocked up now. We will be dropping it about 3/4", the fan is on the bottom as you can see. We will get it all cleaned up once it is wired and plummed.
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: 69CHARGERMD] #460857
09/06/09 09:14 PM
09/06/09 09:14 PM
alabama
mopar addict
mopar addict
alabama
Thanks 69CHARGERMD. Here are the specs for the cooler.
Oil Cooler, 10 1/2 in. x 14 in. x 3 3/4 in. Cooler, 10 in. Fan, 3/8 in. NPT Female.
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: Al_Alguire] #460858
09/06/09 09:18 PM
09/06/09 09:18 PM
alabama
mopar addict
mopar addict
alabama
Thanks for the picture, AL. What kind of lines ( rubber, braided, teflon) do you plan on running to the cooler?
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: mopars rule] #460859
09/06/09 09:20 PM
09/06/09 09:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The lines are braided..
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: Al_Alguire] #460860
09/06/09 10:00 PM
09/06/09 10:00 PM
alabama
mopar addict
mopar addict
alabama
This looks like a really good idea. Plenty of room to work with and plenty of space for air to circulate.
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: mopars rule] #460861
09/06/09 10:50 PM
09/06/09 10:50 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I put mine in back over winter. It seems to do fine as long as I remember to turn the fan on. The temp. runs around 180-185 with the fan, but got up around 220 without. I mounted it on the framerail in front of the rearend on the driver side. I also made a block to connect the braided line to and ran steel line to the cooler. If the trans. needs to come out, the lines can be disconnected from the block.
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: PLUM BAD] #460862
09/06/09 11:59 PM
09/06/09 11:59 PM
Lehigh Acres, Florida
rickstershemi Offline
Mine is mounted very similar to yours....no fan and trans temp is always great...
Rickster
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: rickstershemi] #460863
09/07/09 12:12 AM
09/07/09 12:12 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i have the B&M supercooler with a spare radiator fan bolted onto it mounted in the back of my junk. it's easy to tell if the fans on when doing a burnout, the smoke blows waay out the back, looks more impressive than it is. if you're going to buy a trans cooler, don't buy the S bend type, they reduce the flow each time they do the 180* bend, buy a multi pass type like the B&M which produce no restriction. it's hard to see in the pic since everything is painted black but it's there.
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: ProStDodge] #460864
09/07/09 12:13 AM
09/07/09 12:13 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Yep
Building a little shroud will protect the cooler, and direct much need air over it at the same time.
Re: PUTTING TRANS COOLER TOWARD REAR OF CAR ??????????????? [Re: rebel] #460865
09/07/09 12:40 AM
09/07/09 12:40 AM
alabama
mopar addict
mopar addict
alabama
Well, I have already got the one with the S bend. I guess I will have to try it then if it doesn't do good I will get the B&M cooler. Has anyone here run the S bend cooler or similar type to what I have in the picture above?
