Throttle Cable Lokar vs Imperial Services
#460511
09/06/09 08:42 AM
09/06/09 08:42 AM
Posts: 121 Detroit, MI
kz5rt2
Detroit, MI
Hello, I posted a reply to this discussion thread: https://board.moparts.org/ubbthreads/show...e=2#Post5463178I have the same problem of the four barrels not opening up, I am just not getting the travel. Currently I'm using a Lokar cable and someone mentioned getting one from Imperial Services. Is it possible the lokar cables are not giving enough throw? I've been to car shows and see most Mopar's using cable instead of the stock linkages. Thanks
Re: Throttle Cable Lokar vs Imperial Services
[Re: kz5rt2]
#460512
09/06/09 09:48 AM
09/06/09 09:48 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I have the Lokar cable on my Dart and use the bracket that came with it. The cable mount needs to be lower than the ball stud on the carb in order to get all the throw. The ball stud travels in a arc. In you're photo it looks like the cable mount and ball stud are in line. The cable can only pull through the arc until it's in line again. At this point it is pulling straight and will not open to full throttle. If the cable anchor is mounted lower than the ball stud it pulls it through more of it's arc. This what I found on mine .
[Re: justinp61]
#460514
09/06/09 10:06 AM
09/06/09 10:06 AM
kz5rt2
Detroit, MI
Yes, that makes complete sense with not being able to make a complete arc. I see how how the ball&catch for the throttle needs to be above the mounting bracket. I don't understand how I can do accomplish this. It seems there's so many guys running this exact same setup. Do you have any ideas how I can make this work? I've been fighting this for so long!
[Re: kz5rt2]
#460517
09/06/09 04:40 PM
09/06/09 04:40 PM
Posts: 6,516 Santa Cruz, California
Lefty
Not in my experience. You should be adjusting the length of the throttle cable while holding the carb at WOT. Any kick down cable adjustments should be done after the throttle cable.
[Re: Lefty]
#460519
09/06/09 09:33 PM
09/06/09 09:33 PM
kz5rt2
Detroit, MI
I see from your picture, your cable is lower than the ball and catch. Mine is higher, this might by my problem. I noticed someone posted something about this product. http://www.bouchillonperformance.com/BPEtkdc.aspThis product has the throttle cable bracket much lower than the linkage connection.
[Re: kz5rt2]
#460520
09/07/09 08:13 AM
09/07/09 08:13 AM
Posts: 5,337 the house on the left.
cogen80
why not just use the proper bracket and return springs from lokar?
