Nascar engine swap #460273
09/05/09 06:54 PM
09/05/09 06:54 PM
BX, CT, FL.
B1KILLER Offline OP
B1KILLER  Offline OP
BX, CT, FL.
I was running a B1 motor with a power glide, converted to BB Chrysler bolt pattern. I have a "dodge" Nascar block now, what a night mare. Who can help with this transformation, also have an after market front end, so that will help. Need to know who makes adapter ( motor plate ) so I can bolt my current trans in. Already bought fly wheel for this app.
Re: Nascar abortion [Re: B1KILLER] #460274
09/05/09 07:07 PM
09/05/09 07:07 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
change your title, you might get a responce.. wish i could help ya..
bump
Re: Nascar abortion [Re: Dakota_Don] #460275
09/05/09 07:11 PM
09/05/09 07:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
bump
And probably better luck with asking this in the race secton as well.
Re: Nascar abortion [Re: DaytonaTurbo] #460276
09/05/09 07:33 PM
09/05/09 07:33 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
http://www.campbellenterprises.com/autom...bellhousing.htm
You can get an Ultrbell from many sources. I'm assuming the NASCAR block has the same bolt pattern as a standard A engine. Maybe that is a bad assumption on my part?
Floyd Lippencott IV
Re: Nascar abortion [Re: mr_340] #460277
09/05/09 09:06 PM
09/05/09 09:06 PM
BX, CT, FL.
B1KILLER Offline OP
B1KILLER  Offline OP
BX, CT, FL.
Motor has a bolt pattern that is unique yo Nascar
Re: Nascar abortion [Re: B1KILLER] #460278
09/06/09 09:25 AM
09/06/09 09:25 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Just curious,how do you think the smaller engine will behave with the glide? Won't it really soften up the launch with what I presume will be much less torque than a B1 big block?
Re: Nascar abortion [Re: 67_Satellite] #460279
09/06/09 02:09 PM
09/06/09 02:09 PM
BX, CT, FL.
B1KILLER Offline OP
B1KILLER  Offline OP
BX, CT, FL.
It produced ammost 860 on dyno, dont see a problem. Hope to be turbo, sometime next year, glide should work fine.
