found a 74 motorhome W/440 should be forged...right? #460039
09/05/09 02:24 PM
09/05/09 02:24 PM
Clinton Twp. Michigan
coronet1966d Offline OP
just located a beat but running driving low milage 1974 motorhome with a 440. they used forged internals on the truck/RV stuff in 74 didnt they? anything i should be aware of or look for while scoping out RV motors?
Re: found a 74 motorhome W/440 should be forged...right? [Re: coronet1966d] #460040
09/05/09 02:43 PM
09/05/09 02:43 PM
MNobody Offline
MNobody  Offline
Look at the Dampner, a thick one is usualy a cast crank and the thinner one is forged.
Re: found a 74 motorhome W/440 should be forged...right? [Re: coronet1966d] #460041
09/05/09 03:16 PM
09/05/09 03:16 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
Way MORE than likely a forged crank ..
Any other usable parts on it .. like a frig, roof air...etc ?
Re: found a 74 motorhome W/440 should be forged...right? [Re: dOc …] #460042
09/05/09 03:21 PM
09/05/09 03:21 PM
Don't they usually have the more desirable lower gear sets in the trans?
Re: found a 74 motorhome W/440 should be forged...right? #460043
09/05/09 04:08 PM
09/05/09 04:08 PM
Florida STAYcation
Florida STAYcation
I have heard RUMORS that some truck/motorhome chassis were equipped with a trans that had a 2.77 gear set .. but I have never seen one like that.
MOST motorhomes were WAY over-geared to start off with. Some Class A's having as much as a 4.88 ..some even with a 5.12.
Re: found a 74 motorhome W/440 should be forged...right? [Re: dOc …] #460044
09/05/09 06:06 PM
09/05/09 06:06 PM
Charlotte NC
DCI Offline
DCI  Offline
Charlotte NC
Last two 440 I bought out of Titan MH's were cast crank motors.
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block." Those words must have left a bad taste in his mouth!
Re: found a 74 motorhome W/440 should be forged...right? [Re: dOc …] #460045
09/05/09 06:29 PM
09/05/09 06:29 PM
yeah it has a fridge and it works the guy put new brake boosters in it new manifolds new exhaust ect
Re: found a 74 motorhome W/440 should be forged...right? [Re: coronet1966d] #460046
09/05/09 09:40 PM
09/05/09 09:40 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
I've pulled a few '74 MH 440's over the years (just tore one down last week..) and they all had forged cranks & the heavy six-pack type rods. Some even came with a windage tray.
Re: found a 74 motorhome W/440 should be forged...right? [Re: vdriver] #460047
09/05/09 10:24 PM
09/05/09 10:24 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
Yep, a friend scored one of those, HP rods, windage tray and double chain.
Re: found a 74 motorhome W/440 should be forged...right? [Re: vdriver] #460048
09/06/09 02:52 AM
09/06/09 02:52 AM
any idea what heads will be on it and what compression ratio?
Re: found a 74 motorhome W/440 should be forged...right? [Re: coronet1966d] #460049
09/06/09 04:43 PM
09/06/09 04:43 PM
guesses?
Re: found a 74 motorhome W/440 should be forged...right? [Re: coronet1966d] #460050
09/06/09 04:46 PM
09/06/09 04:46 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Compression ratio will be about 7.5-1 measured.
Sheldon
Re: found a 74 motorhome W/440 should be forged...right? [Re: coronet1966d] #460051
09/06/09 04:47 PM
09/06/09 04:47 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
213 heads. Comp ratio? Are you going to calculate? I'll say 7.8
Re: found a 74 motorhome W/440 should be forged...right? [Re: Pacnorthcuda] #460052
09/06/09 10:23 PM
09/06/09 10:23 PM
scratchnfotraction Offline
mine had 452 heads
what kinda plug is in the head??...
Re: found a 74 motorhome W/440 should be forged...right? [Re: scratchnfotraction] #460053
09/06/09 10:30 PM
09/06/09 10:30 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
Ive had two, still got one, both were cast crank motors...the one I got is low mileage, the other was froze up tight! both were 73 vintage class a motor homes.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: found a 74 motorhome W/440 should be forged...right? [Re: scratchnfotraction] #460054
09/07/09 12:28 AM
09/07/09 12:28 AM
i havnt looked at it yet. its a 1974 30 footer and its painted like the mystery machine
Re: found a 74 motorhome W/440 should be forged...right? [Re: coronet1966d] #460055
09/07/09 06:54 AM
09/07/09 06:54 AM
that will make a cool parts shed when you get the 440 out
Re: found a 74 motorhome W/440 should be forged...right? [Re: scratchnfotraction] #460056
09/07/09 09:38 AM
09/07/09 09:38 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
mine had 452 heads
My 75 Motor home motor I picked up had 452's too and a cast crank. It was cheap and the top end was fresh & ran great...
