wiring car
#459924
09/05/09 11:19 AM
09/05/09 11:19 AM
Posts: 565 IA
landon1
IA
my car is by no means a "race car" - 440 '71 satellite - but, i think i'm going to strip my car of everything i don't need - heat/ac, radio, etc. but i do still need lights, turn signals and brakelights.
anyhow, i was wondering what you guys are doing for wiring harnesses, since i assume most people in the race section wouldn't have most of that stuff either. are you just running generic 8-12 circuit fuse blocks with some wires already connected and running the rest to do what you need?
'71 Satellite Sebring 440
Re: wiring car
[Re: landon1]
#459926
09/05/09 12:39 PM
09/05/09 12:39 PM
Quicktree
Re: wiring car
[Re: landon1]
#459927
09/05/09 06:25 PM
09/05/09 06:25 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
I use the stock wiring as long as it is good I'm a little cheap when it comes to reusing parts on my race car, why buy something to replace a part that is good still and the new part won't make the car go any faster I will, and do strip out any bad or unneeded wires to the air conditioning, cruise control and so on I do have a degree in electronics and 33 yrs working in wires for the phone company so the old cars are a breeze for me to trouble shoot and work on Get a wring schematic and wiring diagram with the color keys for your car so you can tell which wire goes to which component, that will make it, working on the wires, a lot easier to do
Re: wiring car
[Re: Cab_Burge]
#459928
09/05/09 07:21 PM
09/05/09 07:21 PM
Posts: 565 IA
landon1
IA
i would use the stock wiring, but it's been hacked-on pretty good and the - if it was decent, i was considering buying a modern fuse block and connecting what i need and getting rid of the rest. however, i'm looking at a rebel 8 circuit harness - seems to have what i need, similar to t-bucket painless harness i think...just basics to run the car with addition of lights, signals, and wipers
Re: wiring car
[Re: landon1]
#459929
09/05/09 10:31 PM
09/05/09 10:31 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I usually build my own harnesses, re-using the factory plugs as necessary. I usually use self resetting breakers, relays, etc whenever possible. Here's a pic of a panel I built for a 68 Dart. MSD, coil, shift lite switch, circuit breakers, relays all in one panel. Here is a source I use a lot for supplies. www.waytekwire.com
Free advice and worth every penny... Factory trained Slinky rewinder.........
