Page 1 of 3 1 2 3
New Rear Gear Pattern **Update #4** #459471
09/04/09 11:22 PM
09/04/09 11:22 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I am setting up my new gears for the Dart, 742, 8 3/4". Pinion depth calls for 2.717", it's at 2.7175", back lash is at .007", 25# pre load on the pinion, new gears.
Drive side. New, I added a .010" shim to the pinion. Now what?
Re: New Rear Gear Pattern [Re: justinp61] #459472
09/04/09 11:23 PM
09/04/09 11:23 PM
W. Kentucky
W. Kentucky
Coast side.
New
Re: New Rear Gear Pattern [Re: justinp61] #459473
09/04/09 11:24 PM
09/04/09 11:24 PM
W. Kentucky
W. Kentucky
Guide patterns. Am I ok?
Re: New Rear Gear Pattern [Re: justinp61] #459474
09/05/09 12:06 AM
09/05/09 12:06 AM
Out West
408strokerdart Offline
Out West
I'm not sure I would be happy with that. I think I had the gears in and out of my Dana 5 times before I was happy with the pattern. Set up bearings are awesome.
Re: New Rear Gear Pattern [Re: justinp61] #459475
09/05/09 12:09 AM
09/05/09 12:09 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Don't rely on the gauge. The contact pattern is everything. Look at the shape of the pattern. An ideal pattern is wide, with soft rounded edges. It should not look like a knife blade.
Pinion is too far away. Try 0.010" thicker shim then post the result.
Re: New Rear Gear Pattern [Re: DoctorDiff] #459476
09/05/09 12:32 AM
09/05/09 12:32 AM
W. Kentucky
W. Kentucky
Thanks Cass, I'll take it apart tomorrow AM and reset the pinion depth. Brian, you're right on the set up bearings, I just hate to spend $60 on something I won't use for a long time.
Justin
Re: New Rear Gear Pattern [Re: DoctorDiff] #459477
09/05/09 12:36 AM
09/05/09 12:36 AM
Re: New Rear Gear Pattern [Re: justinp61] #459478
09/05/09 07:45 AM
09/05/09 07:45 AM
Andrews,In. U.S.of A.
67_Satellite Online content
67_Satellite  Online Content
Make it look like the upper right pic.
Re: New Rear Gear Pattern [Re: 67_Satellite] #459479
09/05/09 09:21 AM
09/05/09 09:21 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
That set up wouldnt last too long under good power, Im sure it would be noisy on the coast side too.
I sgree with the upper right picture in the manual. .010 thou spacer probably will get ya there. I had my dads dana in and out probbably 6-7 times. I even had the factory dodge scooter block, and pinion depth tools.
What a pain..
Kasey
Re: New Rear Gear Pattern [Re: 67_Satellite] #459480
09/05/09 12:36 PM
09/05/09 12:36 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Or even shoot for the upper left... under power it wil go closer to the right pic...
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459481
09/05/09 01:58 PM
09/05/09 01:58 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Add 0.010" more.
What is your total shim pack thickness? 742 castings usually set up around 0.090"
Re: New Rear Gear Pattern **New Photos** [Re: DoctorDiff] #459482
09/05/09 06:31 PM
09/05/09 06:31 PM
W. Kentucky
W. Kentucky
Cass. it's a 742. It's now at .7896, .008 bl, 20"# pre load on the pinion.
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459483
09/05/09 06:32 PM
09/05/09 06:32 PM
W. Kentucky
W. Kentucky
Coast.
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459484
09/05/09 06:34 PM
09/05/09 06:34 PM
Lehigh Acres, Florida
rickstershemi Offline
Getting better a smidge more ought to do it...fun huh
Rickster
Re: New Rear Gear Pattern **New Photos** [Re: rickstershemi] #459485
09/05/09 06:46 PM
09/05/09 06:46 PM
Out West
Out West
Rickster
Re: New Rear Gear Pattern **New Photos** [Re: rickstershemi] #459486
09/05/09 06:49 PM
09/05/09 06:49 PM
W. Kentucky
W. Kentucky
Rickster
It's been almost more fun than I can stand. It took an hour to get the pre load right. I had to walk away from it for a while . Plus my brother was changing the steering box on his diesel so had to help him too. I'm thinking about putting .020" in it and checking again. It sure is a burden being born stupid (me).
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459487
09/05/09 06:52 PM
09/05/09 06:52 PM
Rickster
You'll get it....taint fun....
Rickster
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459488
09/05/09 08:02 PM
09/05/09 08:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Don't set the preload until you get the pattern right. Otherwise, you must constantly juggle preload shims.
I would try another 0.010". If that is too much, I would decrese the pack 0.005"
Re: New Rear Gear Pattern **New Photos** [Re: DoctorDiff] #459489
09/05/09 09:32 PM
09/05/09 09:32 PM
W. Kentucky
W. Kentucky
Ok, last time tonight, .087" shim pack, .010" bl.
Re: New Rear Gear Pattern **New Photos** [Re: justinp61] #459490
09/05/09 09:33 PM
09/05/09 09:33 PM
W. Kentucky
W. Kentucky
Somebody shoot me.
Page 1 of 3 1 2 3
