I think I got my hook back.
#459381
09/04/09 09:58 PM
09/04/09 09:58 PM
dartman366
Mt. Vernon, Ohio
Took the car out to the local track tonight (pacemaker's) and give it a few test try's and 2 out of 4 passes were good for a 1.34 wheel's up 60ft launches, first one was a easy footbrake pass and went 1.37 60ft and the other one was total driver inability to drive a car , now I got to find out why the car want's to skate around going down the track to the tune of lifting before it got out of hand , I think I need to go back thru the front end alignment cause somthing don't feel right at speed, got one more shot at it before Norwalk.
Re: I think I got my hook back.
[Re: dartman366]
#459382
09/04/09 10:09 PM
09/04/09 10:09 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If you feel like hualin it up here I'll align it for ya
[Re: WILD BILL]
#459383
09/04/09 10:40 PM
09/04/09 10:40 PM
dartman366
Mt. Vernon, Ohio
Thank's for the offer, but no time, I have been using a clip on caster/camber gage that vernmotor has, I have the caster set at 2* positive (top ball joint behind the bottom)and 0 camber, toe in set a 0 at ride height don't know at 1" up, I am putting it back in the garage and re check everything this next week.
[Re: dartman366]
#459384
09/04/09 10:43 PM
09/04/09 10:43 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
What air pressure you running?..maybe go a few clicks stiffer and see what she does..oh...and glad you got your launch back... ....sorry I haven;t typed you a bible yet....no time to focus for 30 minutes...LOL
[Re: Chassisman]
#459385
09/04/09 10:47 PM
09/04/09 10:47 PM
WILD BILL
BROOK PARK, OH
If you have the toe at zero static you are probably getting some toe out down track which could make it unstable at speeds. I would set it at 1/16th toe in on each side.
[Re: WILD BILL]
#459386
09/04/09 11:01 PM
09/04/09 11:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Bill... the worst thing you can have is toe out, the car will start to dart back and forth, the more its toed out the worse it gets... can you get any more caster
[Re: MR_P_BODY]
#459387
09/05/09 09:21 AM
09/05/09 09:21 AM
dartman366
Mt. Vernon, Ohio
Thank's guy's, Ron the air pressure is at 14# (29.5X11.5X15 Phoenix)and the shock's are set at 3 click's up from dead soft, I will work with that next Fri. nite. Bill@ Mike, I am going to recheck and set it up different and raise the front up then set the toe, I want to see what it does when raise and lower the front as to what the toe does, Mike I believe there is more caster to be found, I also plan on reducing the amount of pinion angle from 5* bact to 2-3 I am getting a little rumbling from what sound's like the U joint complaining.
[Re: 340RICK]
#459390
09/05/09 03:17 PM
09/05/09 03:17 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
Get yourself four vinyl tiles to use as toe plates so your tires move easy when you lift the car to check the toe. Use a little wheel bearing grease between them. Store them in a gallon zip lock bag after for next time.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: dartman366]
#459391
09/05/09 06:23 PM
09/05/09 06:23 PM
Posts: 5,987 Anoka County, MN
Leigh
Anoka County, MN
What turned out to be the problem? I think I remember you possibly had coil bind? As for tire pressure, I run that same tire, and I have no problems with 9lbs. I do have 7* caster, and 1/16" toe in at +1" ride height. Car drives like it's on rails. Hey, that's a great idea using vinyl tiles as turntables.
[Re: Leigh]
#459392
09/05/09 06:38 PM
09/05/09 06:38 PM
dartman366
Mt. Vernon, Ohio
Vernmotor showed me the trick with the tile's and it work's like a champ,It wasn't coil bind but the shock's were bottoming out because the spring's were to light and worn out, anything less than 11# on my car and the tires just wad up,,,,bad, I am going to dial in some more caster and redo the toe, this time with the front up an inch.
[Re: 69dart]
#459395
09/06/09 12:43 PM
09/06/09 12:43 PM
dartman366
Mt. Vernon, Ohio
How many screws do you have in back tires? 14 seems like alot. I run 10 - 10.5 in my Hoosier 12 x 32. Where were you at tonight? There were not very many Mopars in S/Pro at Pacemakers tonight. The track was great tonight my car was 1.41 about 6 times today.
Had a family commitment, owed my 82 year old mother a dinner out at a decent restaraunt, Talked to the design engineer for Mickey Thompson and he looked at the car in a video and told me to up the pressure because the side wall's were crushing down too much, I have only raised it 1# so far, He also told me that a smaller slick need's more pressure that a larger tire like a 14X32,,,I will be at the track next weekend on fri and sat.
