Power valve selection? #459195
09/04/09 04:50 PM
09/04/09 04:50 PM
Suffolk,VA
I
ireland383 Offline OP
I
Suffolk,VA
I'm pulling 14" of vacuum at idle and 7 in drive. I have a Holley 3310 that has a 6.5 valve. Should I run a 3.5 valve? I get a hesitation off the line until it picks up. Thanks
Re: Power valve selection? [Re: ireland383] #459196
09/04/09 05:07 PM
09/04/09 05:07 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
I have read about Two methods of selection based on Idle manifold vacuum.
The Holley Factory Method is 1/2 the idle vacuum, so 125-70 or 7.0 PV.
Here is the Holley Factory Link with explanation:
Holley Power Valves
Re: Power valve selection? [Re: D_C] #459197
09/04/09 05:17 PM
09/04/09 05:17 PM
Suffolk,VA
I
I
Suffolk,VA
Now I heard some say go by what it is in gear and some say at idle. Which is it? So if it is at idle then the stock valve is ok?
Re: Power valve selection? [Re: ireland383] #459198
09/04/09 05:21 PM
09/04/09 05:21 PM
D_C Offline
D_C  Offline
In-Gear for Automatic Transmission Vehicles,
Neutral for Manual Transmission Vehicles.
Click This Link for the Holley Factory Explanation...
Re: Power valve selection? [Re: D_C] #459199
09/04/09 05:23 PM
09/04/09 05:23 PM
Suffolk,VA
I
I
Suffolk,VA
So it is a 3.5 needed. Thanks
Re: Power valve selection? [Re: ireland383] #459200
09/04/09 05:25 PM
09/04/09 05:25 PM
D_C Offline
D_C  Offline
No!!! If you have 14 In/Hg, 1/2 of that is 7 In/Hg so you select a 7.0 Power Valve. The 6.5 probably would work fine.
Click on this Link:
Holley Power Valve Selection
Re: Power valve selection? [Re: D_C] #459201
09/04/09 05:28 PM
09/04/09 05:28 PM
Suffolk,VA
I
I
Suffolk,VA
I read it. Idling in gear I'm at 7", so 1/2 it and it's 3.5 correct?
Re: Power valve selection? [Re: ireland383] #459202
09/04/09 05:34 PM
09/04/09 05:34 PM
D_C Offline
D_C  Offline
Sorry, I thought earlier you said you had 14 In/Hg, but that was your Neutral Idle.
So, Yes, if you have 7 In/Hg at "In-Gear Idle, 1/2 that would indicate a 3.5 or Holley P/N: 125-35 Power Valve.
Here is the Exact Quote from the Holley Website:
Each Holley power valve is stamped with a number to indicate the vacuum opening point. For example, the number “65” indicates that the power valve will open when the engine vacuum drops to 6.5" or below. An accurate vacuum gauge, such as Holley P/N
26-501, should be used when determining the correct power valve to use.
A competition or race engine which has a long duration high overlap camshaft will have low manifold vacuum at idle speeds. If the vehicle has a manual transmission, take the vacuum reading with the engine thoroughly warmed up and at idle. If the vehicle is equipped with an automatic transmission, take the vacuum reading with the engine thoroughly warmed up and idling in gear. In either case, the power valve selected should be 1/2 the intake manifold vacuum reading taken.
EXAMPLE: 13” Hg vacuum reading divided by 2 = 6.5 power valve. If your reading divided by 2 lands on an even number you should select the next lowest power valve. EXAMPLE:
8” Hg vacuum reading divided by 2 = 4 power valve.
Since there is no #4 power valve you should use a 3.5.
Re: Power valve selection? [Re: D_C] #459203
09/04/09 05:36 PM
09/04/09 05:36 PM
Suffolk,VA
I
I
Suffolk,VA
Thanks for the info.
Re: Power valve selection? [Re: ireland383] #459204
09/04/09 05:42 PM
09/04/09 05:42 PM
D_C Offline
D_C  Offline
Good Luck with it.
Make sure you have/use the Correct Power-Valve Gasket. The "Newer" Stepped Power-Valve requires the New Thicker PV gasket to seal.
Experience: Couple weeks back, I bought a brand new Holley Factory Power-Valve and used the "New" gasket included in the package.
It turned out to be the Old 1/2-thickness gasket that the factory included. I didn't notice, and had fuel leaking past the power-valve 100% of the time, draining the fuel-bowl, etc.
Re: Power valve selection? [Re: ireland383] #459205
09/04/09 06:35 PM
09/04/09 06:35 PM
do check the AP tip in/duration
Re: Power valve selection? [Re: ireland383] #459206
09/04/09 08:26 PM
09/04/09 08:26 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I know Holley says 1/2 idle vac for an opening point, but my experience is that often causes a hesitation. There is no vac signal to the PV at idle so a higher (earlier) opening point will not affect the ide mixture. I usually run a 9.5 in almost everything I set up. In my Cuda right now, I have a 10.5 hi flow. My idle vac is 9" or so in gear. I can run a 9.5 and even an 8.5 if the weather is right. But by 6.5, I have a stumble at tip in. I am sure that Holley has forgotten more than I know about carbs, but I have dealt with this issue many, many times. If it helps, I get my PVs from O'Reilly's Auto Parts. They are the same price as Jegs, usually have it the next day and there is no shipping.
Master, again and still
Re: Power valve selection? [Re: ireland383] #459207
09/04/09 11:13 PM
09/04/09 11:13 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""I'm pulling 14" of vacuum at idle and 7 in drive."
I think that you have to address the 7"hg drop from Neutral to Drive before you choose your power valve. That is a big drop in vacuum. I would suggest that you try to tune the carb with the car warmed up with the emergency brake applied with the tranny in D. I think that you are lean in D. If this is true, then this would cause the hesitation off the line like you described.
