Best way to remove vin rivets #459173
09/04/09 04:46 PM
09/04/09 04:46 PM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
Not stirring the pot with a rebody stuff but my metal dash in my dart is getting changed. Thus, I need to keep the vin for my car.
Re: Best way to remove vin rivets [Re: moparpollack] #459174
09/04/09 04:56 PM
09/04/09 04:56 PM
Auburn Hills, Michigan
K
kieron_kohlmann Offline
K
grind them off from the back side and pop em out
Re: Best way to remove vin rivets [Re: kieron_kohlmann] #459175
09/04/09 05:03 PM
09/04/09 05:03 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Weren't VIN Tags mounted, using "Special" rivets (not your typical Pop-Rivets?)... For when it needs to be remounted....
Re: Best way to remove vin rivets [Re: kieron_kohlmann] #459176
09/04/09 05:05 PM
09/04/09 05:05 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Then you could glue it back on with the same rivits and no one would know.
Re: Best way to remove vin rivets [Re: Challenger 1] #459177
09/04/09 05:09 PM
09/04/09 05:09 PM
85086
Lil Herman
Lil Herman
85086
Cool thanks for the help.
Re: Best way to remove vin rivets [Re: moparpollack] #459178
09/05/09 02:49 PM
09/05/09 02:49 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Call the CIA,FBI and Alert the Moparts police and have them ALL watch cause if you don't your car will be fake & that you are commiting a felony. I suggest keeping the original dash frame in the trunk and make a vin tag for your new dash that says *CTRUNKCOMPARTMENT*
Well atleast most would say that but go ahead and grind from the bottom and re-use...
Re: Best way to remove vin rivets [Re: QuickBpBp] #459179
09/05/09 03:22 PM
09/05/09 03:22 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
no, most would not say that.
nothing even close to illegal/fraudulent about what he is doing.
as said grind off from bottom and reuse rosette heads with some adhesive.
Re: Best way to remove vin rivets [Re: nomore65BelvJim] #459180
09/05/09 04:51 PM
09/05/09 04:51 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This can't be Moparts... There haven't been a dozen wild accusations of fraud & deceit... So Thief!! Rebody!! Fraud!! OK now that we have that out of the way, Grind the rivits from the back side & use adhesive....
Re: Best way to remove vin rivets [Re: moparpollack] #459181
09/05/09 04:55 PM
09/05/09 04:55 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
If your Dart is 69 or newer it has vin numbers on the radiator support and under the trunk weatherstrip if vin questions ever come up in the future.
Re: Best way to remove vin rivets [Re: 69MOPE] #459182
09/05/09 06:48 PM
09/05/09 06:48 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
You can also find a pair of rosette rivets on ebay for $25 or so. My tag had been removed so I bought a pair and riveted it back on neatly.
My '72 Dart's dash VIN matches the radiator support and trunk lip stampings, but my driver's door has a sticker from a different Canadian Dart. Could be interesting if a cop looks elsewhere than the dash
-Charles
Re: Best way to remove vin rivets [Re: nomore65BelvJim] #459183
09/05/09 08:28 PM
09/05/09 08:28 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Well its a slow night and the Beach Boys don't go for an hour, so I can't resist:
And how exactly do you really know that?
Re: Best way to remove vin rivets [Re: Challenger 1] #459184
09/05/09 08:54 PM
09/05/09 08:54 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
Also agree, GRIND them off, don't try drilling, that will spin the rivet scratching the face of the tag
