Best way to remove vin rivets
#459173
09/04/09 04:46 PM
09/04/09 04:46 PM
moparpollack
Lil Herman
Lil Herman
85086
Not stirring the pot with a rebody stuff but my metal dash in my dart is getting changed. Thus, I need to keep the vin for my car.
Re: Best way to remove vin rivets
[Re: kieron_kohlmann]
#459176
09/04/09 05:05 PM
09/04/09 05:05 PM
Challenger 1
Cincinnati, Ohio
grind them off from the back side and pop em out
Then you could glue it back on with the same rivits and no one would know.
[Re: Challenger 1]
#459177
09/04/09 05:09 PM
09/04/09 05:09 PM
moparpollack
Lil Herman
Lil Herman
85086
Cool thanks for the help.
[Re: moparpollack]
#459178
09/05/09 02:49 PM
09/05/09 02:49 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Call the CIA,FBI and Alert the Moparts police and have them ALL watch cause if you don't your car will be fake & that you are commiting a felony. I suggest keeping the original dash frame in the trunk and make a vin tag for your new dash that says *CTRUNKCOMPARTMENT*
Well atleast most would say that but go ahead and grind from the bottom and re-use...
[Re: QuickBpBp]
#459179
09/05/09 03:22 PM
09/05/09 03:22 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
no, most would not say that.
nothing even close to illegal/fraudulent about what he is doing.
as said grind off from bottom and reuse rosette heads with some adhesive.
[Re: 69MOPE]
#459182
09/05/09 06:48 PM
09/05/09 06:48 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
You can also find a pair of rosette rivets on ebay for $25 or so. My tag had been removed so I bought a pair and riveted it back on neatly. My '72 Dart's dash VIN matches the radiator support and trunk lip stampings, but my driver's door has a sticker from a different Canadian Dart. Could be interesting if a cop looks elsewhere than the dash -Charles
[Re: Challenger 1]
#459184
09/05/09 08:54 PM
09/05/09 08:54 PM
Posts: 1,945 Grand Rapids MI
N9671X2
Grand Rapids MI
Also agree, GRIND them off, don't try drilling, that will spin the rivet scratching the face of the tag
