Hoosier Radial Slicks which ones? #458551
09/03/09 07:13 PM
09/03/09 07:13 PM
Anonymous OP
Anonymous OP
should i get the CO6 or CO7 compound on the 30 x 10.5 x 15 Hoosier radial Slick.
does anyone else make a radial slick, im not liking Hoosiers anymore, they just dont last.
Re: Hoosier Radial Slicks which ones? #458552
09/03/09 07:15 PM
09/03/09 07:15 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Ask Fred
Re: Hoosier Radial Slicks which ones? [Re: blown572dart] #458553
09/03/09 07:24 PM
09/03/09 07:24 PM
Anonymous OP
Anonymous OP
Ask Fred
your hero right?
slicks something you'll never experience in your lifetime!!
Re: Hoosier Radial Slicks which ones? #458554
09/03/09 07:42 PM
09/03/09 07:42 PM
Anonymous OP
Anonymous OP
so can i get an adult answer to my question please.
Re: Hoosier Radial Slicks which ones? #458555
09/03/09 07:43 PM
09/03/09 07:43 PM
Anonymous OP
Anonymous OP
Ask Fred
your hero right?
Seems kinda harsh.
Re: Hoosier Radial Slicks which ones? #458556
09/03/09 07:58 PM
09/03/09 07:58 PM
Orlando Florida
Orlando Florida
Ask Fred
your hero right?
Slick is what you SWALLOW
Re: Hoosier Radial Slicks which ones? #458557
09/03/09 07:59 PM
09/03/09 07:59 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
If you need help in the traction dept., use the softer compound, CO7. They will not last as long as the CO6's nor be quite as fast; at least that has been my experience. You do know that 30 X 9 Hoosiers come in two different circumferences, don't you?
Re: Hoosier Radial Slicks which ones? [Re: SuperStocker] #458558
09/03/09 08:16 PM
09/03/09 08:16 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
my M/T 30x9 radials lasted 56 runs. I went back to bias slicks and yes they are slower by .08 at least.
Re: Hoosier Radial Slicks which ones? [Re: SuperStocker] #458559
09/03/09 08:24 PM
09/03/09 08:24 PM
Anonymous OP
Anonymous OP
SUPERSTOCKER, thanks im leaning towards the 06 compound, im so close to that 9 second pass with my 63 so im looking for all the help i can get.i bet 40 passes total with them is all ill get.its a heavy car.
i even went to a smaller 30 x 10.5 over the 29 x 10.5w for less rolling resistence/
i heard radial slicks might get me a few more mph.
Re: Hoosier Radial Slicks which ones? #458560
09/03/09 08:28 PM
09/03/09 08:28 PM
Orlando Florida
Orlando Florida
Re: Hoosier Radial Slicks which ones? [Re: blown572dart] #458561
09/03/09 09:23 PM
09/03/09 09:23 PM
Anonymous OP
Anonymous OP
http://www.yellowbullet.com/forum/chat/flashchat.php
thanks for ruining my post!! grow up.
Re: Hoosier Radial Slicks which ones? #458562
09/03/09 09:26 PM
09/03/09 09:26 PM
Orlando Florida
Orlando Florida
Re: Hoosier Radial Slicks which ones? [Re: blown572dart] #458563
09/03/09 09:38 PM
09/03/09 09:38 PM
Anonymous OP
Anonymous OP
there were problems with the hoosier radials, something about the tires wobbling and hard to control at high speeds. later SLIP
Re: Hoosier Radial Slicks which ones? #458564
09/03/09 10:01 PM
09/03/09 10:01 PM
Vacherie, Louisiana
super gas
super gas
Vacherie, Louisiana
If you have problems with these tires, you either need to add air pressure or check your car...
Re: Hoosier Radial Slicks which ones? #458565
09/03/09 10:04 PM
09/03/09 10:04 PM
Vacherie, Louisiana
super gas
super gas
Vacherie, Louisiana
9 out of 10, you are killing the tires in the burnout.
Re: Hoosier Radial Slicks which ones? [Re: SuperStocker] #458566
09/03/09 10:08 PM
09/03/09 10:08 PM
Anonymous OP
Anonymous OP
how long of a burnout do you do with these tires and how much psi.
im going to order a set tomorrow.thx.
Re: Hoosier Radial Slicks which ones? #458567
09/03/09 10:18 PM
09/03/09 10:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought a set of the 30 x 9 Hoosier radial slicks to use at the track. I have the shorter 29.5 tall tires and they work great for me. I got my best 60 yet on them the last time out. I even drove the 90 miles too and home from the track on them. It took 3 passes to get them too hook real good. I like them as they work fine for me and fit my stock wheelwells real good. Ron
Re: Hoosier Radial Slicks which ones? [Re: 383man] #458568
09/03/09 11:51 PM
09/03/09 11:51 PM
Anonymous OP
Anonymous OP
Radials only lasted 30 runs on my car...If you get 50-60 runs you are doing well. Once they start going away they are done...On the bright side they are worth a solid tenth in most cases.
Re: Hoosier Radial Slicks which ones? #458569
09/04/09 12:03 AM
09/04/09 12:03 AM
Vacherie, Louisiana
super gas
super gas
Vacherie, Louisiana
At the first hint of smoke, it's been long enough. I run at least 20lbs and have run as much as 28lbs on a track with teeth. Again, your car must work to fully utilize these tires and track prep has to be good too. I can get at least 200 passes on a set.
Re: Hoosier Radial Slicks which ones? [Re: SuperStocker] #458570
09/04/09 06:23 AM
09/04/09 06:23 AM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
I never saw 200 passes - 120 was about it for my Duster. Tire pressure was normally 22 - 23 PSI.
Keep burn out short!!!!
Swap sides after about the first 10 passes, then leave them until they start to go away. The signal I noticed was 60 foot time were inconsistent. At that point, I swapped sides twice to get maybe another 20 runs, then time for new ones.
Paul
