915 Head Flow Results #458436
09/03/09 04:47 PM
09/03/09 04:47 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Had my set of 915s flowed. I bought these a few months ago from a member who had bought them from another member. Dont know who ported them.
Here are the #s
I
.100 67.3
.200 137.9
.300 210.4
.400 264.3
.500 265
.600 270
E
.100 47.6
.200 101.9
.300 134.6
.400 179.8
.500 198.3
.600 211.5
They were flowed at 28'' with a 4.280 bore. I dont know if the exhaust had a pipe or not.
Anything stand out or look funny on the numbers?
Would the flow #s change much when used with a 4.375 fixture? If so, more or less, usually?
I'll have some numbers to compare as they are flowing my BS heads that were ported by Dwayne.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 915 Head Flow Results [Re: Von] #458437
09/04/09 09:38 AM
09/04/09 09:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
bigger bore would unshroud the intake so that I'm pretty sure would pick up some , adding a pipe on the exh I have alsoseen picked up flow .
they look good , I'll PM you my address where to ship them .
Re: 915 Head Flow Results [Re: JohnRR] #458438
09/04/09 10:27 AM
09/04/09 10:27 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m no expert but those look like some descent numbers and if I remember right, my Ed Vickroy ported 906`s went 278-279 intake and low 200`s on the exhaust and pushed my dart to 10.40`s at will in my daily driver till they cracked.
Re: 915 Head Flow Results [Re: Thumperdart] #458439
09/05/09 10:56 AM
09/05/09 10:56 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: 915 Head Flow Results [Re: Dodgem] #458440
09/05/09 12:11 PM
09/05/09 12:11 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Did you have them cc'd on the chamber side?
Moparlee
Re: 915 Head Flow Results [Re: Robbins] #458441
09/05/09 12:15 PM
09/05/09 12:15 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
They were supposed to, but didnt.
Im gonna pull my 452s off and have them flowed also and will have both sets cc'd.
Re: 915 Head Flow Results [Re: Von] #458442
09/05/09 05:36 PM
09/05/09 05:36 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
could you measure the width/hight in the pushrod pinch area?i am just wondering the size[CSA].those flow the same as my 346's 2.14/1.81
