Does anyone make custom gears? #458410
09/03/09 04:47 PM
09/03/09 04:47 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I have a friend building a 5.9 Cummins 73 Dart. He needs the rear gearing to be in the 2.5/2.7 range does anyone make custom gears for a Dana 60? Jim
Re: Does anyone make custom gears? [Re: rt66jim] #458411
09/04/09 12:44 AM
09/04/09 12:44 AM
Call Dana Corporation Ford had 3.30 ratio gears in there mid 1970 to probally early 1980s 3/4 ton V8 4 speed gas motors, check your local junk yards or your local Ford dealers heavy mechanics, maybe one of them pigeon holed a set BTW, what front suspension is your buddy going to use to hold that Dart up with
Re: Does anyone make custom gears? [Re: Cab_Burge] #458412
09/04/09 06:29 AM
09/04/09 06:29 AM
Indiana
79_W200 Offline
79_W200  Offline
Indiana
Dodge and furd also used a 2.73 gear in the 3/4 1 ton truck in the late 80's and early 90's they were put in a dana 61 which had the inside of the housing machined farther over for the big pinion other wise the same as a dana 60 I will have to check i think i have a set of these gears p.m. me if your interested
1979 W200 470
Re: Does anyone make custom gears? [Re: 79_W200] #458413
09/04/09 12:00 PM
09/04/09 12:00 PM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
I dont think a dana 61 gear cluster works in a 60 housing does it? I know alot of guys that thought they were getting a great deal on a 60 on to find out it was a 61, and there cant be to many 61's out there.
Re: Does anyone make custom gears? [Re: The Avg. Valiant] #458414
09/04/09 03:20 PM
09/04/09 03:20 PM
Indiana
79_W200 Offline
79_W200  Offline
Indiana
all the parts are the same except the side of the housing is machined out 1/4 or so to allow easy fit of the large pinon other wise carier, gear, brgs. all interchange but if you want to run much more than a 4.10 you will need spacers with the thick thick gears
1979 W200 470
Re: Does anyone make custom gears? [Re: rt66jim] #458415
09/05/09 07:49 AM
09/05/09 07:49 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
You can get some made but you will pat BIG $$$$ (best estimate is $2000+) for them. If you want a source and contact # PM me.
The cost will include the Engineering, Summary development, material cost, Machine time, Heat treat and matching.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Does anyone make custom gears? [Re: W.I.N. Racing] #458416
09/05/09 08:20 AM
09/05/09 08:20 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Likely be the same $ for say a 742? And if bought in multiples cost be much better per pair? Sounds like the start of a group buy to me.
Re: Does anyone make custom gears? [Re: jcc] #458417
09/05/09 08:24 AM
09/05/09 08:24 AM
Q
Quicktree Offline
Quicktree  Offline
Q
why the need for such a gear? even with a diesel you would think something a little lower would work? is he racing daytona with it?
Re: Does anyone make custom gears? [Re: rt66jim] #458418
09/05/09 10:18 AM
09/05/09 10:18 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
It is impossible to make a ratio that high for a stock Dana 60 housing/carrier.
Re: Does anyone make custom gears? [Re: Quicktree] #458419
09/05/09 10:36 AM
09/05/09 10:36 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Thank all of of you for your replies. Since this build is a diesel and is being setup for 1/4 mile racing. The RPM limit on the engine is 4500. The trans will be a turbo 400 built by Neal Chance. According to the Wallace cal. A 2.86 would do the job. But if you allow a little for converter slip it needs to be a little taller. Jim
Re: Does anyone make custom gears? [Re: DoctorDiff] #458420
09/05/09 10:37 AM
09/05/09 10:37 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Cass can the stock Dana 60 hsg be machined so it would work? Jim
Re: Does anyone make custom gears? [Re: rt66jim] #458421
09/05/09 10:40 AM
09/05/09 10:40 AM
Q
Quicktree Offline
Quicktree  Offline
Q
taller tire.
Re: Does anyone make custom gears? [Re: rt66jim] #458422
09/05/09 10:54 AM
09/05/09 10:54 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I don't think the stock housing can be easily modified.
You could run a 3.07 geared Dana 61 rear.
You could also try a used set of 2.47-2.76 gears in a Nodular 9" casting with Daytona pinion support and 35 spline Detroit Locker or spool. I don't know how the 28 spline pinion would hold up, however.
Re: Does anyone make custom gears? [Re: Quicktree] #458423
09/05/09 03:53 PM
09/05/09 03:53 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Quicktree, don't have any more room for taller tires. He doesn't want a 9" in it. It's a Mopar thing. Jim
Re: Does anyone make custom gears? [Re: DoctorDiff] #458424
09/06/09 09:09 AM
09/06/09 09:09 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
When looking in a salvage yard
what vehicle and year
would have the Dana 61 with 3.07 ?
I would like to get one to replace a Chrysler 9.25 with 3.21, or I would like to find a QuikChange diff.
Back in the 1980s
there was a guy near Mt Vernon KY
who just personally liked cutting gears
and had an extensive shop with much older gear cutting machinery.
He could make nearly any gear style including hypoid and did one-off jobs for the mining and trucking industry.
I am not sure if he is still alive or still working.
Re: Does anyone make custom gears? [Re: Cab_Burge] #458425
09/06/09 09:22 AM
09/06/09 09:22 AM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Run a one speed glide in there and let that torque go to work!
Re: Does anyone make custom gears? [Re: 360view] #458426
09/06/09 09:34 AM
09/06/09 09:34 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Some late '70s-early '80s Ford 3/4 ton trucks used Dana 61 rears. You also can use the front ring and pinon out of an early '90s Dodge diesel/automatic 4 x 4 truck in the Dana 61 rear housing.
Re: Does anyone make custom gears? [Re: 360view] #458427
09/06/09 10:03 AM
09/06/09 10:03 AM
nc
moeflo Offline
moeflo  Offline
nc
A Dodge/Cummins truck with a 3sp torqueflite is probably the easiest place to find them. '89 through 91.5 model years I believe. Non intercooled trucks. Anything with an OD was 3.54 or steeper.
Re: Does anyone make custom gears? [Re: rt66jim] #458428
09/06/09 10:30 AM
09/06/09 10:30 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
with a turbo 400?
The nine inch would be less intrusive into the "mopar thing" realm.
maybe a gear vendors unit would help with a dana 61.
interesting build.
Re: Does anyone make custom gears? [Re: Cab_Burge] #458429
09/06/09 10:51 AM
09/06/09 10:51 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I had a set of those gears, sold them to a member for $50..I always thought those would make a sweet street gear for a large engine 550+cubes and a set of 30" tall tires.
