Re: Does anyone make custom gears?
[Re: Cab_Burge]
#458412
09/04/09 06:29 AM
09/04/09 06:29 AM
Posts: 317 Indiana
79_W200
Indiana
Dodge and furd also used a 2.73 gear in the 3/4 1 ton truck in the late 80's and early 90's they were put in a dana 61 which had the inside of the housing machined farther over for the big pinion other wise the same as a dana 60 I will have to check i think i have a set of these gears p.m. me if your interested
1979 W200 470
[Re: The Avg. Valiant]
#458414
09/04/09 03:20 PM
09/04/09 03:20 PM
Posts: 317 Indiana
79_W200
Indiana
all the parts are the same except the side of the housing is machined out 1/4 or so to allow easy fit of the large pinon other wise carier, gear, brgs. all interchange but if you want to run much more than a 4.10 you will need spacers with the thick thick gears
1979 W200 470
[Re: rt66jim]
#458415
09/05/09 07:49 AM
09/05/09 07:49 AM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
You can get some made but you will pat BIG $$$$ (best estimate is $2000+) for them. If you want a source and contact # PM me. The cost will include the Engineering, Summary development, material cost, Machine time, Heat treat and matching.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#458416
09/05/09 08:20 AM
09/05/09 08:20 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Likely be the same $ for say a 742? And if bought in multiples cost be much better per pair? Sounds like the start of a group buy to me.
[Re: DoctorDiff]
#458420
09/05/09 10:37 AM
09/05/09 10:37 AM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
It is impossible to make a ratio that high for a stock Dana 60 housing/carrier.
Cass can the stock Dana 60 hsg be machined so it would work? Jim
[Re: rt66jim]
#458421
09/05/09 10:40 AM
09/05/09 10:40 AM
Quicktree
Thank all of of you for your replies. Since this build is a diesel and is being setup for 1/4 mile racing. The RPM limit on the engine is 4500. The trans will be a turbo 400 built by Neal Chance. According to the Wallace cal. A 2.86 would do the job. But if you allow a little for converter slip it needs to be a little taller. Jim
taller tire.
[Re: 360view]
#458427
09/06/09 10:03 AM
09/06/09 10:03 AM
Posts: 247 nc
moeflo
nc
When looking in a salvage yard what vehicle and year would have the Dana 61 with 3.07 ?
A Dodge/Cummins truck with a 3sp torqueflite is probably the easiest place to find them. '89 through 91.5 model years I believe. Non intercooled trucks. Anything with an OD was 3.54 or steeper.
[Re: rt66jim]
#458434
09/07/09 09:31 AM
09/07/09 09:31 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Interesting about the Cummins 4 cyl diesels in the bread delivery trucks with GM automatics. Would that same bell housing made for the Turbo 400 allow you to use a 4 cylinder Cummins with one of the new GM 6T70 six speed automatics ? http://www.theautochannel.com/news/2005/08/25/141299.html
