Numbers matching question? #458170
09/03/09 09:11 AM
09/03/09 09:11 AM
Albuquerque, New Mexico
moparmatt Offline OP
Believe it or not I have been into my mopars since the late 70s and I have never really looked or cared about numbers matching issues as I have always known the history of all of my cars now as i am possibly going to sell a couple of them how does the vin actually show up in the engine # and manual trans, and rear end, on 68 high performance plymouth's? thanks
Re: Numbers matching question? [Re: moparmatt] #458171
09/03/09 09:18 AM
09/03/09 09:18 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
First off there is NO VIN on the rear axle assembly on any mopar of that era .
68 is stamped on the bellhousing flange near the oil pressure sensor and in the same spot on an automatic or on the id pad on the side of the trans on a 4 speed . It will be the last 8 of the VIN , and will NOT match the number stamped on the body . the only way to tie the body number to the VIN is with the FACTORY BROADCAST sheet .
Re: Numbers matching question? [Re: JohnRR] #458172
09/03/09 09:24 AM
09/03/09 09:24 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No VIN or Sequence numbers on Dana 60 axle housings, but the assembly numbers and date codes stamped into them would have aligned with the cars Scheduled Production Date so it's always nice to check and confirm them. After the basic VIN/SO numbers have been found to match, dated coded parts are the "next level" when it comes to checking originallity IMO
Re: Numbers matching question? [Re: JohnRR] #458173
09/03/09 09:25 AM
09/03/09 09:25 AM
where on a hemi 4 spd road runner? should the engine block # have the vin #s in it?
Re: Numbers matching question? [Re: moparmatt] #458174
09/03/09 09:26 AM
09/03/09 09:26 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Matt, Hemi's would have the number stamped in the location that John pointed out.
Re: Numbers matching question? [Re: ScottSmith_Harms] #458175
09/03/09 09:31 AM
09/03/09 09:31 AM
Scott thanks, should the last 8 digits of the vin show up on the engine block also? I think I have the part # I dont think I have the right # the number I am looking at is 4262447004
Re: Numbers matching question? [Re: moparmatt] #458176
09/03/09 09:35 AM
09/03/09 09:35 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Post a pic of your number and I'll try to figure out what you are looking at. Here's a guess before seeing a pic.
4262447004 = 426 Cubic inches 2447 April 09, 1968 004 4th engine assembled on shift
That looks like the assembly number that would be found on the bottom oil pan rail of the engine?
Here's what a trans stamping looks like (passenger side raised pad)
Re: Numbers matching question? [Re: ScottSmith_Harms] #458177
09/03/09 09:43 AM
09/03/09 09:43 AM
thats exactly where i found that number Scott, i will look at the top area up near the oil pressure sending unit? The area near the flange that attaches to the bell housing ?
Re: Numbers matching question? [Re: moparmatt] #458178
09/03/09 09:44 AM
09/03/09 09:44 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, exactly
Re: Numbers matching question? [Re: ScottSmith_Harms] #458179
09/03/09 09:45 AM
09/03/09 09:45 AM
JohnRR Offline
JohnRR  Offline
Matt did you miss the picture Scott posted above ?
Re: Numbers matching question? [Re: ScottSmith_Harms] #458180
09/03/09 09:46 AM
09/03/09 09:46 AM
the number I found on the trans is 63292 does that make any sense? Thank you Scott as always you are very helpful!!
Re: Numbers matching question? [Re: moparmatt] #458181
09/03/09 09:51 AM
09/03/09 09:51 AM
I saw the picture John, I am going down to the garage to find all of the numbers. Like i said I never really cared about the number stuff as I have had all of my cars for years, Im kind of embarrassed! And I just and out of the 14 cars I have 12 broadcast sheets that i have just found and some extras that i will post soon. Of course my hemi car is one of the broadcast sheets I dont have?
Re: Numbers matching question? [Re: moparmatt] #458182
09/03/09 11:22 AM
09/03/09 11:22 AM
JohnRR Offline
JohnRR  Offline
is that number CAST or STAMPED ?? CASTING numbers are pretty much USELESS to identity the trans.
you want to look at the STAMPED numbers on the pad picture scott posted above .
Re: Numbers matching question? [Re: JohnRR] #458183
09/03/09 03:12 PM
09/03/09 03:12 PM
I found the trans # PP8333603 and the engine block number that I could read was 2812 was all i could make out which does match up with the Vin!!!! yeah!!!! and the rear end is 4 24 8 B 1 and there was another # on the trans which was it looked like
OB 168292 ????
Re: Numbers matching question? [Re: moparmatt] #458184
09/03/09 03:42 PM
09/03/09 03:42 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
You should post a pic of the trans numbers, that looks like a later model trans if I am deciphering it correctly. The rear end dates seem to align with the engines assembly date, those tow are likely original to the car.
