340 Engine... How to determine pushrod length?? #458139
09/03/09 08:56 AM
09/03/09 08:56 AM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Guys!
I'm preparing my 340 for reassembly and I've been searching (somewhat casually) for the proper method in determining push-rod length. (BTW: I've been known in the past to skip this step and just slap an engine together and see what happens... )
I didn't see anything in the tech area, and even many of the guys at the machine shops aren't sure (unless it is a chevy ).
My 340 has the stock cam, lifters (hydraulic), and non-adjustable rocker shafts/arms. They all mention using a black or blue felt marker to mark the tops of two valves, assembling with two push rods & rocker arms/shaft and rolling the engine over a few times.
Then check the affect that the rocker arm has on the top of the valve.
I can't see how affective this method is with non-adjustable rocker arms, although I think I understand the intent of the procedure.
They also mention using a solid lifter & the adjustable push-rods, to determine the proper length. But they say that the stock lifters can be used (some-how) also.
Basically you lengthen and shorten the adjustable push-rod to achieve the correct imprint on the top of the valve. (Then use that length to order new ones of that length).
Has anyone used this method with non-adjustable rockers?
Any advice would be appreciated.
Thanks!
Tim...
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: 340 Engine... How to determine pushrod length?? [Re: cuda_tim] #458140
09/03/09 09:06 AM
09/03/09 09:06 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Did you have machine work done to the block? If not and everything is stock I personally would not bother but that`s me.
Re: 340 Engine... How to determine pushrod length?? [Re: cuda_tim] #458141
09/03/09 09:08 AM
09/03/09 09:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yep sounds like chevy builders doing that will tell you if your rocker to valve tip geomerty is correct but the length of the pushrod will NOT do anything for it since you have a SHAFT MOUNTED system and once you bolt it down and torque to spec it is what it is. You have to use spacers under the shaft OR remove material from the cast stands to change that relationship.
Has the block been decked alot ? heads shaved alot , head gasket thickness vs. original ? These are things that aeffect the pushrod length on big block and small block mopars .
Re: 340 Engine... How to determine pushrod length?? [Re: mopars4ever] #458142
09/03/09 09:11 AM
09/03/09 09:11 AM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Yes, heads were shaved significantly. In fact, I need to use a shim...
But more importantly, I think I'd like to know the best way to do this...
Tim...
Re: 340 Engine... How to determine pushrod length?? [Re: cuda_tim] #458143
09/03/09 09:15 AM
09/03/09 09:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Tim...
what do you mean ... I NEED TO USE A SHIM ????
Re: 340 Engine... How to determine pushrod length?? [Re: cuda_tim] #458144
09/03/09 09:46 AM
09/03/09 09:46 AM
From Dave Hughes & co: At 60% of total valve lift (50% if BB) the centerline thru the pushrod and adj screw should be a straight line viewed from the front of the eng. Shorten/lengthen the pushrod and or saddle shims (or milling) to achieve it. 1-2 threads showing and include the lash if it's a solid cam/lifters & if hyd use a junk hyd lifter w the cup welded solid. Then rocker tip side alignment & shims on the shaft to correct that then check the wipe pattern.
Re: 340 Engine... How to determine pushrod length?? [Re: JohnRR] #458145
09/03/09 10:18 AM
09/03/09 10:18 AM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Tim...
Ok, my machine shop performed a valve to piston clearance check for me and they advised using a 0.020 shim, in addition to the normal Fel-Pro head gasket.
I don't remember the numbers exactly (I'm at work), but I think that the numbers fell out like this:
Using the Clay method, the clearance between the intake valve and the piston valve relief was 0.036. They recommended 0.100 on the exhaust side.
If you figure that the Fel-Pro head gasket compresses to 0.039 and the shim is 0.020, this should get me to 0.095.
0.036 + 0.020 + 0.039 = 0.095.
Anybody?
Tim...
Re: 340 Engine... How to determine pushrod length?? [Re: cuda_tim] #458146
09/03/09 10:30 AM
09/03/09 10:30 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Tim...
Anybody?
Tim...
Never heard of a head gasket shim?
Re: 340 Engine... How to determine pushrod length?? [Re: cuda_tim] #458147
09/03/09 10:32 AM
09/03/09 10:32 AM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
I had the same problem when I had the heads shaved .070. The machine shop could not tell me how much shorter my pushrods needed to be. You would think there would be a formula similar to the one used in shaving the intake to fit. I found it easier to get new custom cut pushrods and adjustable rockers.
Re: 340 Engine... How to determine pushrod length?? [Re: repad] #458148
09/03/09 11:03 AM
09/03/09 11:03 AM
Shoreview,MN
65vert Offline
65vert  Offline
Shoreview,MN
End result on 69 340-Chrome moly pushrod through chrome moly rocker arm. Hamburger sells or used to sell adjustable rocker arms which was my net result.
Re: 340 Engine... How to determine pushrod length?? [Re: RapidRobert] #458149
09/03/09 11:19 AM
09/03/09 11:19 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
doning my firesuit ...
That's some BAD info from Hughes , I'm surprised ... really , I am ...
Hughes bootlickers , don't waste your energy ...
Re: 340 Engine... How to determine pushrod length?? [Re: cuda_tim] #458150
09/03/09 11:21 AM
09/03/09 11:21 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Tim...
Anybody?
Tim...
use the standard fel-pros (Q8553PT) they're actually .054" compressed. that'll get you .090" clearance. if you're still concerned, try retarding the camshaft 2 degrees.
2017 Grand Cherokee Overland
Re: 340 Engine... How to determine pushrod length?? [Re: repad] #458151
09/03/09 01:23 PM
09/03/09 01:23 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
P2 = 7.500 - D/Cos(14)
P2 - Desired (new) push rod length
7.500 - Stock small block pushrod length
D - Amount of height removed; Amount milled from heads + Amount shaved of the block deck + head gasket compressed height difference
No longer taking $h!t from anyone!
Re: 340 Engine... How to determine pushrod length?? [Re: DUFFMAN] #458152
09/03/09 05:42 PM
09/03/09 05:42 PM
YOU DO NOT ADJUST PUSHROD LENGTH BASED ON VALVE TO PISTON CLEARANCE!!!!!!!!!!!!!!!!!!!!!!!!
Re: 340 Engine... How to determine pushrod length?? #458153
09/03/09 10:38 PM
09/03/09 10:38 PM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Ok, so when does the pushrod length need to be considered? And how it is verified without adjustable rockers?
My original post only suggests that I would like to determine the length... since I want to make sure it is correct.
Especially since I know that when using the stock cam, (per my machine shop guy) I need to add a shim, since the valve to piston clearance is already tighter than normal.
And especially since I know that (when I disassembled the engine) the intake manifold mounting holes had previously been "hogged out" a great deal in order to get the intake to fit correctly.
Anybody?
Re: 340 Engine... How to determine pushrod length?? [Re: cuda_tim] #458154
09/04/09 09:17 AM
09/04/09 09:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
when you deck the block and the head A LOT , which sounds like the case here since you don't have enough piston to valve clearance now , take one of your old pushrods put it in place with head on the block and pick a spot in the valley that you can easily get at with wrenches and cut about an inch and half out of it , thread the inside ... FINE THREAD .... get a piece of threaded rod and 2 nuts , wala ADJUSTABLE PUSHROD ... find out the length you need with it .
Re: 340 Engine... How to determine pushrod length?? [Re: JohnRR] #458155
09/04/09 11:39 AM
09/04/09 11:39 AM
Some of you guys are confused. PUSHROD LENGTH is adjusted to maintain VALVE CLEARANCE "lash" when adjusting valves AND to maintain decent rocker arm geometry. IT HAS NOTHING TO DO with piston to valve clearance. Pushrod lenght is set WITH THE VALVES CLOSED
Piston to valve clearance is determined by cam lift, by valve timing, by the type and height of pistons and deck. Unless I mis--read the type of cam you posted you have very little valve/ piston clearance.
If you need more valve / piston clearance you need to
go to a lower lift cam
go to lower ratio rockers which also lower the lift
Buy different pistons with deeper reliefs
Figure a way to cut deeper reliefs--not a backyard project for the usual shadetree--these must be milled, the pistons re--balanced and quite possibly the engine rebalanced
I'm starting to wonder if this entire question is not mis construed. Maybe you have more piston / valve clearance than you were told?? In any case pushrod length is NOT the answer
Re: 340 Engine... How to determine pushrod length?? #458156
09/04/09 12:28 PM
09/04/09 12:28 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
another way to change valve to piston clearance is to change the cam timing. moving the ICL around can drastically change V-P clearance.
Re: 340 Engine... How to determine pushrod length?? #458157
09/04/09 12:31 PM
09/04/09 12:31 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Using stock non-adjustable rockers and hydraulic lifters you need only bolt on the rocker assembly,find the distance(adjustable pushrod ball&ball ends)and at rest,valve 100% closed add your desired preload(start the plunger downward)Lock your adjustment on the pushrod and you have your proper length.Make sure you are on the(bottom) of the cam lobe at true basecircle.
Re: 340 Engine... How to determine pushrod length?? #458158
09/04/09 03:11 PM
09/04/09 03:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Some of you guys are confused. PUSHROD LENGTH is adjusted to maintain VALVE CLEARANCE "lash" when adjusting valves AND to maintain decent rocker arm geometry. IT HAS NOTHING TO DO with piston to valve clearance. Pushrod length is set WITH THE VALVES CLOSED
The only person confused here seems to be YOU , no one said anything, anywhere, in this thread about adjusting piston to valve clearance with the length of the pushrods till you brought it up .
If you go back and reread you'll see he was told to use a HEAD GASKET SHIM to regain his piston to valve clearance .
