340 Engine... How to determine pushrod length??
#458139
09/03/09 08:56 AM
09/03/09 08:56 AM
Posts: 589 Waynesboro, PA
cuda_tim
Waynesboro, PA
Guys! I'm preparing my 340 for reassembly and I've been searching (somewhat casually) for the proper method in determining push-rod length. (BTW: I've been known in the past to skip this step and just slap an engine together and see what happens... ) I didn't see anything in the tech area, and even many of the guys at the machine shops aren't sure (unless it is a chevy ). My 340 has the stock cam, lifters (hydraulic), and non-adjustable rocker shafts/arms. They all mention using a black or blue felt marker to mark the tops of two valves, assembling with two push rods & rocker arms/shaft and rolling the engine over a few times. Then check the affect that the rocker arm has on the top of the valve. I can't see how affective this method is with non-adjustable rocker arms, although I think I understand the intent of the procedure. They also mention using a solid lifter & the adjustable push-rods, to determine the proper length. But they say that the stock lifters can be used (some-how) also. Basically you lengthen and shorten the adjustable push-rod to achieve the correct imprint on the top of the valve. (Then use that length to order new ones of that length). Has anyone used this method with non-adjustable rockers? Any advice would be appreciated. Thanks! Tim...
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: 340 Engine... How to determine pushrod length??
[Re: cuda_tim]
#458141
09/03/09 09:08 AM
09/03/09 09:08 AM
Posts: 74,962 U.S.S.A.
JohnRR
U.S.S.A.
Yep sounds like chevy builders doing that will tell you if your rocker to valve tip geomerty is correct but the length of the pushrod will NOT do anything for it since you have a SHAFT MOUNTED system and once you bolt it down and torque to spec it is what it is. You have to use spacers under the shaft OR remove material from the cast stands to change that relationship. Has the block been decked alot ? heads shaved alot , head gasket thickness vs. original ? These are things that aeffect the pushrod length on big block and small block mopars .
[Re: cuda_tim]
#458143
09/03/09 09:15 AM
09/03/09 09:15 AM
JohnRR
U.S.S.A.
Did you have machine work done to the block? If not and everything is stock I personally would not bother but that`s me.
Yes, heads were shaved significantly. In fact, I need to use a shim...
But more importantly, I think I'd like to know the best way to do this...
Tim...
what do you mean ... I NEED TO USE A SHIM ????
[Re: cuda_tim]
#458144
09/03/09 09:46 AM
09/03/09 09:46 AM
RapidRobert
From Dave Hughes & co: At 60% of total valve lift (50% if BB) the centerline thru the pushrod and adj screw should be a straight line viewed from the front of the eng. Shorten/lengthen the pushrod and or saddle shims (or milling) to achieve it. 1-2 threads showing and include the lash if it's a solid cam/lifters & if hyd use a junk hyd lifter w the cup welded solid. Then rocker tip side alignment & shims on the shaft to correct that then check the wipe pattern.
[Re: JohnRR]
#458145
09/03/09 10:18 AM
09/03/09 10:18 AM
cuda_tim
Waynesboro, PA
Tim...
Ok, my machine shop performed a valve to piston clearance check for me and they advised using a 0.020 shim, in addition to the normal Fel-Pro head gasket.
I don't remember the numbers exactly (I'm at work), but I think that the numbers fell out like this:
Using the Clay method, the clearance between the intake valve and the piston valve relief was 0.036. They recommended 0.100 on the exhaust side.
If you figure that the Fel-Pro head gasket compresses to 0.039 and the shim is 0.020, this should get me to 0.095.
0.036 + 0.020 + 0.039 = 0.095.
Anybody?
Tim...
[Re: cuda_tim]
#458146
09/03/09 10:30 AM
09/03/09 10:30 AM
Challenger 1
Cincinnati, Ohio
Tim...
Anybody?
Tim...
Never heard of a head gasket shim?
[Re: RapidRobert]
#458149
09/03/09 11:19 AM
09/03/09 11:19 AM
JohnRR
U.S.S.A.
doning my firesuit ...
That's some BAD info from Hughes , I'm surprised ... really , I am ...
Hughes bootlickers , don't waste your energy ...
[Re: cuda_tim]
#458150
09/03/09 11:21 AM
09/03/09 11:21 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Tim...
Anybody?
Tim...
use the standard fel-pros (Q8553PT) they're actually .054" compressed. that'll get you .090" clearance. if you're still concerned, try retarding the camshaft 2 degrees.
[Re: DUFFMAN]
#458152
09/03/09 05:42 PM
09/03/09 05:42 PM
YOU DO NOT ADJUST PUSHROD LENGTH BASED ON VALVE TO PISTON CLEARANCE!!!!!!!!!!!!!!!!!!!!!!!!
[Re: cuda_tim]
#458154
09/04/09 09:17 AM
09/04/09 09:17 AM
JohnRR
U.S.S.A.
Ok, so when does the pushrod length need to be considered? And how it is verified without adjustable rockers?
when you deck the block and the head A LOT , which sounds like the case here since you don't have enough piston to valve clearance now , take one of your old pushrods put it in place with head on the block and pick a spot in the valley that you can easily get at with wrenches and cut about an inch and half out of it , thread the inside ... FINE THREAD .... get a piece of threaded rod and 2 nuts , wala ADJUSTABLE PUSHROD ... find out the length you need with it .
[Re: JohnRR]
#458155
09/04/09 11:39 AM
09/04/09 11:39 AM
Some of you guys are confused. PUSHROD LENGTH is adjusted to maintain VALVE CLEARANCE "lash" when adjusting valves AND to maintain decent rocker arm geometry. IT HAS NOTHING TO DO with piston to valve clearance. Pushrod lenght is set WITH THE VALVES CLOSED
Piston to valve clearance is determined by cam lift, by valve timing, by the type and height of pistons and deck. Unless I mis--read the type of cam you posted you have very little valve/ piston clearance.
If you need more valve / piston clearance you need to
go to a lower lift cam
go to lower ratio rockers which also lower the lift
Buy different pistons with deeper reliefs
Figure a way to cut deeper reliefs--not a backyard project for the usual shadetree--these must be milled, the pistons re--balanced and quite possibly the engine rebalanced
I'm starting to wonder if this entire question is not mis construed. Maybe you have more piston / valve clearance than you were told?? In any case pushrod length is NOT the answer
#458158
09/04/09 03:11 PM
09/04/09 03:11 PM
JohnRR
U.S.S.A.
Some of you guys are confused. PUSHROD LENGTH is adjusted to maintain VALVE CLEARANCE "lash" when adjusting valves AND to maintain decent rocker arm geometry. IT HAS NOTHING TO DO with piston to valve clearance. Pushrod length is set WITH THE VALVES CLOSED
The only person confused here seems to be YOU , no one said anything, anywhere, in this thread about adjusting piston to valve clearance with the length of the pushrods till you brought it up .
If you go back and reread you'll see he was told to use a HEAD GASKET SHIM to regain his piston to valve clearance .
