angle on rear shackel #458011
09/02/09 10:49 PM
09/02/09 10:49 PM
Can , Nova Scotia , Cape Breto...
caper Offline OP
caper  Offline OP
With your rear tires just of the ground , What should the angle be on the rear shackels? Should the bottom of the shackel be towards the front or back. How many degrees. The reason I am asking is , sometimes the car picks up the front end a small bit , than drops and unloads the tires. I have an Alterktion front suspenson and all I can get is 3 1/2 shock travel.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: angle on rear shackel [Re: caper] #458012
09/02/09 10:55 PM
09/02/09 10:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Should never go forward of vertical... why cant you
get more front travel... also what rear shocks
Re: angle on rear shackel [Re: MR_P_BODY] #458013
09/02/09 11:06 PM
09/02/09 11:06 PM
caper Offline OP
caper  Offline OP
I think that is all you can get with the Alterktion front suspension , shocks are very short. I have Rancho 9 way shocks , I set them at 9 , I have tried them at 7 when the track has bad traction.
Re: angle on rear shackel [Re: caper] #458014
09/02/09 11:12 PM
09/02/09 11:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you taken a video to see whats happening... 3 1/2
is pretty short for a heavier car(not a tube chassis)
Re: angle on rear shackel [Re: MR_P_BODY] #458015
09/02/09 11:21 PM
09/02/09 11:21 PM
caper Offline OP
caper  Offline OP
Here is a video when I first ran it. Since than I lowered the rear and it hooks better , but still does not lift the front end the way it should. Weight is 49.5% front , 50.5% back. My best 60 ft on a real good track was 1.44
http://www.youtube.com/watch?v=VM1T2zYnzfQ
Re: angle on rear shackel [Re: caper] #458016
09/02/09 11:23 PM
09/02/09 11:23 PM
caper Offline OP
caper  Offline OP
When I have the rear tires of the ground I put an angle meter on the shackel and it is pointing 7* towards the front.
Re: angle on rear shackel [Re: caper] #458017
09/02/09 11:31 PM
09/02/09 11:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I am suprized you can get a 1.44 you car doesnt transfer,
I wish your camera man was taking the pic from a
quartering angle so you can see the front and the
rear tire... you can hear your spinning.... the rear
doesnt move neither does the front... what was the tire
pressure. To me the whole car looks like its binding up
Re: angle on rear shackel [Re: caper] #458018
09/02/09 11:34 PM
09/02/09 11:34 PM
Never have the rear shackle pointing to the front, that will pull the car down as it goes past the center of the upper hangars causing the car to porpoise. Can you move the rear hangar forward with spacers or make some longer hangars? Or is the rear springs moved into the frames? If so that makes a lot easier to move the rear hangar forward I like to see at least 30 degrees shacle angle to the rear (ear spring eye closer to the bumper than the upper hangar eye is), more if possible
Re: angle on rear shackel [Re: MR_P_BODY] #458019
09/02/09 11:35 PM
09/02/09 11:35 PM
caper Offline OP
caper  Offline OP
Tire pressure at that time was 18 lbs M/T street radials. After I lowered the rear I got the 1.44 60 ft . I believe on that run it was around 1.51.
Re: angle on rear shackel [Re: caper] #458020
09/02/09 11:43 PM
09/02/09 11:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When you say "lowered" are you talking tire pressure
or you lowered the rear of the car... if you can lower
the rear of the car, that would help... but what is
the tire pressure now... have you tried even lower yet
Re: angle on rear shackel [Re: MR_P_BODY] #458021
09/02/09 11:50 PM
09/02/09 11:50 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Alan Jones
Re: angle on rear shackel [Re: MR_P_BODY] #458022
09/02/09 11:57 PM
09/02/09 11:57 PM
caper Offline OP
caper  Offline OP
When I put the boxes in to move the springs into the frame rails I drilled two sets of holes for the front spring eye . one in the stock location , the other two are higher in the box , which allowed me to lower the back of the car.
I have tried air pressure from 11 lbs to 22 lbs , now it likes it at 21 lbs. In the last year the engine was down on power , just last week I did a leakdown test , the cylinders were down 23% ( 150 lbs cranking pressure. I just reringed it this past week , will be going to the track this weekend. Is it possible I am not getting any rotation because the angle on the shackel is towards the front. If so I have split mono leaf springs . I can drill a new hole for the center bolt on the rear leaf to change the angle towards the rear.
Re: angle on rear shackel [Re: caper] #458023
09/03/09 12:24 AM
09/03/09 12:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
As the pinion tries to rotate up its tilting down
on the rear of the spring.... as soon as the shackle
gets to vertical it pulls the body down(which is
pulling the axle up)... do you have clamps on the
rear of the springs... if so take 1 or 2 off
You want the front of the spring STIFF but you want
the rears fairly soft
Re: angle on rear shackel [Re: Cab_Burge] #458024
09/03/09 02:40 PM
09/03/09 02:40 PM
Wi.
65_gt_rag_402 Offline
Wi.
I just checked my set up >> shackle angle on my dart with caltracs. It is verticle straight down. apparanetly that is not Good !! How thick of spacer do you think I would need ?
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: angle on rear shackel [Re: MR_P_BODY] #458025
09/03/09 03:01 PM
09/03/09 03:01 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Let me apologize for asking such a dumb question, but if you jack the car up like the OP said he did (and I am assuming he didn't jack it up under the diff, sorry if you did), what would prevent the shackle from pointing forward? If I put mine up on jack stands, under the frame in front of the tires, I'm positive my shackles point forward too. Wouldn't the weight of the diff, with tires off the ground, cause the springs to "bow" down, pulling the shackles forward?
I have the same set up as Caper, and am trying to get the most out of my set-up too.
gary
Re: angle on rear shackel [Re: codfish] #458026
09/03/09 03:13 PM
09/03/09 03:13 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
gary
Yes they would.
Re: angle on rear shackel [Re: cudabunch] #458027
09/03/09 04:25 PM
09/03/09 04:25 PM
caper Offline OP
caper  Offline OP
I checked the angle on the rear shackels today. with the frame rails level the car sitting on the rear wheels it is 26* the bottom of the shackel pointing to the rear. When I lift the rear tires of the ground it is 8* pointing to the front. I found out why my 60 ft dropped off . Last fall I was after raising the front end 3 " for ground clearence while street driving. Forgot to lower it at the first of the year. It sucks getting old and forgetfull.
Re: angle on rear shackel [Re: codfish] #458028
09/03/09 05:04 PM
09/03/09 05:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
gary
When you jack up the car(frame) both sides of the
spring bow... if you are under acceleration the front
segments are trying to tip up while tipping the rears
down(front is lifting the body but also pushing down
on the diff) and now the rear segments are trying to
pull the body back down but the difference is in the
shackle, its allowing the spring to basically move
forward till its vertical ... remember its trying
to pull pull down... once it gets to vertical its
the spring is just loading it harder... not letting
it go forward
Re: angle on rear shackel [Re: caper] #458029
09/03/09 05:11 PM
09/03/09 05:11 PM
gregsdart Offline
gregsdart  Offline
Shoot for an angle of 45 degrees. You might have to make new upper holes for the rear shackles, and you can make longer than stock ones if you desire more rear rise. This photo is off my dart back in 1985 with two inch longer shackles, 45 degrees angle at rest, SS springs.
