refrigerant coils put in burn out area #457829
09/02/09 08:35 PM
09/02/09 08:35 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Anybody know of any tracks that have installed refrigerant coils in the burn out areas of the track?
Fastest 300
Re: refrigerant coils put in burn out area [Re: Crizila] #457830
09/02/09 08:43 PM
09/02/09 08:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why would they?
Re: refrigerant coils put in burn out area [Re: Quicktree] #457831
09/02/09 09:26 PM
09/02/09 09:26 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Yea I think it is denver .Has them out to the 60 ft...Keep the starting line cool..better hook. Not sure why you just want them in the burn out box ??
Re: refrigerant coils put in burn out area [Re: VernMotor] #457832
09/02/09 09:38 PM
09/02/09 09:38 PM
ky
68roadrunner Offline
ky
i heard that I-57 in benton il. has the cooling lines.
Re: refrigerant coils put in burn out area [Re: Quicktree] #457833
09/02/09 10:07 PM
09/02/09 10:07 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
why would they?
Because John doesn't want to get all sweaty doing his burnouts in the Great White Whale.
Re: refrigerant coils put in burn out area [Re: VernMotor] #457834
09/02/09 11:13 PM
09/02/09 11:13 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I think it's farther out than 60'. They got money to spend for that, but can't afford to bring running water to the facility.
Re: refrigerant coils put in burn out area [Re: 64Post] #457835
09/02/09 11:20 PM
09/02/09 11:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you ever seen it change the track temp( do they
run the chillers for the normal weekend races)
Re: refrigerant coils put in burn out area [Re: MR_P_BODY] #457836
09/03/09 01:55 AM
09/03/09 01:55 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I haven't run a car there in 10 years. If I got the story straight they use the coils to maintain a certain surface temp. IDK if they chill it during the summer months and heat it during the spring and fall. I wouldn't be surprised if they did it just to lengthen the racing $eason.
Re: refrigerant coils put in burn out area [Re: slantzilla] #457837
09/03/09 11:14 AM
09/03/09 11:14 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
why would they?
Actually big D, I've been trying to convince everybody that my 3rd round loss ( napping at the light ) at the Nats was caused by heat, but nobody's buyin it. They are letting me off the hook on the "your old" thing though.
Fastest 300
Re: refrigerant coils put in burn out area [Re: Crizila] #457838
09/03/09 03:00 PM
09/03/09 03:00 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: refrigerant coils put in burn out area [Re: Dodgem] #457839
09/03/09 03:23 PM
09/03/09 03:23 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Fastest 300
Re: refrigerant coils put in burn out area [Re: Crizila] #457840
09/03/09 05:58 PM
09/03/09 05:58 PM
Park Forest, IL
Park Forest, IL
Hey, you probably made it farther than anyone giving you grief, didn't ya?
I gots other problems. Either I'm too early or I can't drive the big end.
I have made 10 passes this year without anything falling out of the motor though.
Re: refrigerant coils put in burn out area [Re: slantzilla] #457841
09/03/09 06:15 PM
09/03/09 06:15 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Ive wondered before if coils under the track couldnt be used to prevent dew from setting as night falls?
Re: refrigerant coils put in burn out area [Re: 68roadrunner] #457842
09/03/09 09:20 PM
09/03/09 09:20 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Benton does something most tracks could try also
they run sprinklers on the track starting line to keep track temp down .But like most tracks we take temps and 135 is slimy not till you get 115 or cooler does it really start biting .
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
