Re: jet size ????
[Re: 70dusterjohn]
#457502
09/02/09 11:54 AM
09/02/09 11:54 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
How bout the timing.. Should I change it or leave it a 36??? Its a crank trigger set up.. Thanks Cab..
Only one way to find out I like 34 to 36, not all BB Mopars are the same, try 34 and then try 38 at the track the same day. look closely at the plugs, at least two, and then the ET slip, all of it
Re: jet size ????
[Re: 70dusterjohn]
#457506
09/02/09 09:01 PM
09/02/09 09:01 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
John my combo is identical. I've only got 3 full 1/4 mile passes(9 1/8 mile passes) on it but every time I jet up it goes faster, I'm up around 96 or 97 jets right now. I bumped the timing around and it seemed to run the same ET anywhere from 34-38 so I left it at 34.
Re: jet size ????
[Re: 70dusterjohn]
#457508
09/02/09 10:05 PM
09/02/09 10:05 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Similar setup maybe [14-1] 1150 dom 100 square, C-14. 38 timing. Rarely change the jet.
The little old lady from Pasadena is back!
