Frame ties #457305
09/02/09 08:14 AM
09/02/09 08:14 AM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Can someone tell me what size tubing is used for the bolt-in subframe connectors that Mopar Performance sells?
Re: Frame ties [Re: Scamp451] #457306
09/02/09 01:09 PM
09/02/09 01:09 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think it is 2x2 inch I use 2x3 .083 and slide it into the rear subframes and plug weld it to the sides as well as as to the edge of the rear subframe edges. I weld it to the back side of the transmission crossmember also
Re: Frame ties [Re: Cab_Burge] #457307
09/02/09 01:21 PM
09/02/09 01:21 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I used 1 5/8 .134 wall round tube.. I also tie the ladder bar cross bar mount into the frme ties, and have done some other tubes in there.. this was on my brothers dart and it seems to work well....
Re: Frame ties [Re: Scamp451] #457308
09/02/09 02:37 PM
09/02/09 02:37 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It's 1"x2" tubing.
Re: Frame ties [Re: Challenger 1] #457309
09/02/09 03:26 PM
09/02/09 03:26 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
i use 2x3 tubing. it slips over the rear sub frame and to the back of the tran cross frame then weld it all in. like MR Cab says
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: Frame ties [Re: 65cuda] #457310
09/02/09 04:24 PM
09/02/09 04:24 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I use 2X3 but keep it under the floor and overlap the rear frame and box the back end.
SRT DEMON ONE SEAT
Re: Frame ties [Re: Ron Silva] #457311
09/02/09 04:25 PM
09/02/09 04:25 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
one more
SRT DEMON ONE SEAT
Re: Frame ties [Re: Ron Silva] #457312
09/02/09 04:33 PM
09/02/09 04:33 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
2X2 here, I notch the rear frame rails and weld. I also use a 3/16" plate in the front welded to the transmission cross member.
Re: Frame ties [Re: justinp61] #457313
09/02/09 04:35 PM
09/02/09 04:35 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Front.
Re: Frame ties [Re: justinp61] #457314
09/02/09 09:38 PM
09/02/09 09:38 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Thanks for the answer to the original question and all the pics... nice looking work on all of them.
The challenge I am faced with though is that I want to run mufflers and turn the exhaust out to the side, but this is a back-halfed car. I have to either go under the 2x3 crossmember
or out the sides, so I am trying to keep the frame rails that run from front to back as high as possible.
If I go with 2x3 tubing from the 2x3 X member to the front near the torsion bars, I will probably have to lay the 2x3 "flat" rather that "tall" if you know what I mean, so I have that extra ground cleaance. Only other options I can think of to keep them high is to run them inside the car (which I am not crazy about), or use smaller tubing.
I have to give up something one way or another. I guess there is oval exhaust tubing too, but never worked with it.
Re: Frame ties [Re: Scamp451] #457315
09/02/09 10:05 PM
09/02/09 10:05 PM
Cincinnati, Ohio
Cincinnati, Ohio
Sounds like you could use some aircraft tubing, very low profile. You gave me I idea for my next car. These are a bunch of old wind stands from my TAD.
Re: Frame ties [Re: Scamp451] #457316
09/02/09 10:18 PM
09/02/09 10:18 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
The challenge I am faced with though is that I want to run mufflers and turn the exhaust out to the side, but since this is a back-halfed I have to either go under the 2x3 crossmember
or out the sides. So trying to keep the frame railes running from front to back as high as possible. I go with 2x3 tubing from the 2x3 X member to the front near the torsion bars, I will probably have to lay the 2x3 "flat" rather that "tall" if you know what I mean, so I have that extra ground cleaance. Only other options to keep them high is to run them inside the car which I am not crazy about, or use smaller tubing.
I have to give up something one way or another. I guess there is oval exhaust tuping too, but never worked with it.
I had the same issue so i gave up my X-piped exhaust and am using car chemistry header inserts from Jegs.
Re: Frame ties [Re: Cheatham] #457317
09/02/09 11:11 PM
09/02/09 11:11 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
if you use 2x3 you cut the floor in the rear and fit it tight and weld it up or you can also look at the US CAR TOOL connectors. i have them on my car and they look like the car came with them and they dont hang low
Re: Frame ties [Re: sixpackgut] #457318
09/03/09 11:57 AM
09/03/09 11:57 AM
Locomotion Offline
Locomotion  Offline
2x2 at .083" or a little thicker should be plenty, especially if you tie the roll bar into it. 2 short bars just behind the seats angled in from the main hoop and welded onto the frame connectors help a lot. Tack-welding to the floor where the connectors touches also helps.
It's not always how big or thick the tubing is but how it's put together. Race car fabricators save a lot of weight by "triangulating" the tubing in the chassis/roll bars.
I never cared for "bolt-in" frame connectors or their smaller size.
Re: Frame ties [Re: 70dusterjohn] #457319
09/03/09 01:25 PM
09/03/09 01:25 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Me too. But I used two per side.
Plenty strong, and really made the car feel "tighter"
codfish
Re: Frame ties [Re: codfish] #457320
09/03/09 01:50 PM
09/03/09 01:50 PM
Deerfield, Ohio
Deerfield, Ohio
codfish
Yep, I only used one bar but I have many others in there to help make it stronger. It all ties in to the ladder bars. I thought it was going to be way hevier than just the 2x3 box but it was 3lbs lighter. Even with all those extra bars.. And I still have room for my exhaut pipes...
