How to tell if 440 crank is drilled for 4 speed? #457288
09/02/09 07:55 AM
09/02/09 07:55 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I've got a 1966 440 crank that is going to be mated to an 833 4-speed.
How can I tell if this crank needs drilled for a 4-speed or not. It has about 1 1/2" inch deep hole at the end of the crank already (flywheel end).
Thanks for any tips.
Re: How to tell if 440 crank is drilled for 4 speed? [Re: nd65] #457289
09/02/09 08:52 AM
09/02/09 08:52 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I think all the vintage steel ones were. sounds like yours is!
Order a pilot bushing and make sure it fits?
Re: How to tell if 440 crank is drilled for 4 speed? [Re: Dodgem] #457290
09/02/09 09:11 AM
09/02/09 09:11 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
do i smell a big motor going in that pretty '65 ? missed you at the Paddock, lew.
Re: How to tell if 440 crank is drilled for 4 speed? [Re: lewtot184] #457291
09/02/09 10:01 AM
09/02/09 10:01 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Good suggestion about the test fit.
Good to here from you Lew. I am starting my build. I sold the stroker kit last fall and am doing a budget stock stroke build, but I am going 4-speed.
You know, I forgot all about the Paddock Show. Saturday was my sons birthday so we were up at Muncie for a while. Did they have a good turn out?
Take care.
Re: How to tell if 440 crank is drilled for 4 speed? [Re: nd65] #457292
09/02/09 10:44 AM
09/02/09 10:44 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
This is a steel 383 crank drilled for a pilot:
Re: How to tell if 440 crank is drilled for 4 speed? [Re: nd65] #457293
09/02/09 11:05 AM
09/02/09 11:05 AM
Some warnings from the past: You can't tell by looking. Some crank holes lacked ONLY about 3/8 or so of being deep enough. This is where the idea of cutting off 4 speed shafts got into play, as you don't need to cut off much more than the champher on the front of the shaft.
My recollection is that if a standard pilot will fit, it's OK. Even this has to be carefully done, because many holes were "rough bored" just not to full size. If the pilot bushing "just doesn't want to go in" then it's undersize. You used to be able to buy undersize pilot bushings.
Only way I know of to find out for SURE is to come up with an accurate measurement from the flange on a known "stick" crank and measure hole depth.
Re: How to tell if 440 crank is drilled for 4 speed? #457294
09/02/09 03:15 PM
09/02/09 03:15 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
Ive never personally had a problem before with the hole not being deep enough but many,many times i found the pilot bushing hole was not finish reamed out so the bushing wouldnt fit.If you use a late model roller pilot bearing that fits in the outer bore on the crank you will eliminate that problem.
Re: How to tell if 440 crank is drilled for 4 speed? [Re: ogopogo] #457295
09/02/09 03:30 PM
09/02/09 03:30 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i have an undersized pilot bushing in my 440 and it worked great. i got it from NAPA i think it was about $1 like a regular pilot bushing.
Re: How to tell if 440 crank is drilled for 4 speed? [Re: 65rbdodge] #457296
09/02/09 05:07 PM
09/02/09 05:07 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
On the other hand, my very first 383 (from an automatic car) had the right size finished hole for the pilot bushing, but was drilled about 3/8" too shallow for my 4-speed!
I just deepened it the required amount with a 9/16" drill.
So anything is possible - check it first... and I also recommend the roller bearing that fits in the crank register.
-Charles
Re: How to tell if 440 crank is drilled for 4 speed? [Re: DrCharles] #457297
09/02/09 08:26 PM
09/02/09 08:26 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
vdriver, that looks like my crank.
The hole is about 1 3/4" deep with 2 different diameters. The diameter nearest the flange is about .875 and 1" deep. It then steps down a little bit.
Any got a part number for the roller bearing?
Re: How to tell if 440 crank is drilled for 4 speed? [Re: nd65] #457298
09/02/09 08:30 PM
09/02/09 08:30 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Mancini has them
Re: How to tell if 440 crank is drilled for 4 speed? [Re: ogopogo] #457299
09/02/09 11:09 PM
09/02/09 11:09 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Re: How to tell if 440 crank is drilled for 4 speed? [Re: nd65] #457300
09/03/09 09:05 AM
09/03/09 09:05 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Take care.
turn out was about the same as last year. there was an absolutely beautiful '65 plymouth belvedere 2dr post there. this car is a must see; red, black interior, big block, 5spd. the guy who owns it may be in your neck of the woods; lives around Pendleton.
Re: How to tell if 440 crank is drilled for 4 speed? [Re: lewtot184] #457301
09/03/09 12:58 PM
09/03/09 12:58 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
I think you can get the roller bearing from any parts store.If you get a bearing say for an 01 dodge ram v-8 it would be correct. (keep your receipt as Im not 100% positive about this)
Re: How to tell if 440 crank is drilled for 4 speed? [Re: ogopogo] #457302
09/03/09 02:04 PM
09/03/09 02:04 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Never say never. My 76 440 crank does NOT have a pilot hole at all! The later style roller bearing would be my only option to run a 4-sp.
Re: How to tell if 440 crank is drilled for 4 speed? [Re: nd65] #457303
09/03/09 03:46 PM
09/03/09 03:46 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
If the crank is finish reamed for a bushing the bore will measure .9375". Cranks that are only pilot drilled but not finish reamed will measure about .8125".
Re: How to tell if 440 crank is drilled for 4 speed? [Re: John_Kunkel] #457304
09/03/09 04:44 PM
09/03/09 04:44 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
John, thanks so much for the numbers.
