torsion bar question #456688
09/01/09 06:21 PM
09/01/09 06:21 PM
Anonymous OP
Anonymous OP
A friend gave me a pair of slant six torsion bars for my Challenger.
I know they're marked left and right, but does it matter which end goes into the frame socket?
If you switch the bar end for end, it will twist the opposite direction. Does that matter?
My original bars were marked as follows;
left front
CZT
779L
left rear
779L
499
right front
778R
529
right rear
CTJ
778R
The slant six bars are marked as follows;
left
775L
063
UVL
775l
right
774R
063
UVW
774R
I'll appreciate any help on this.
Re: torsion bar question #456689
09/01/09 06:34 PM
09/01/09 06:34 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
IF you swap the bars end to end they will twist in the same direction. It doesn't matter.
Re: torsion bar question [Re: Jim_Lusk] #456690
09/01/09 06:37 PM
09/01/09 06:37 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
like a bolt with a nut, no matter wich one you tight ( bolt or nut ), allways will be CW. Turn it around and still will be CW to tight.
on the other side will be the same but imagine is a CCW thread to tight, no matter which end
Re: torsion bar question [Re: NachoRT74] #456691
09/01/09 07:32 PM
09/01/09 07:32 PM
Anonymous OP
Anonymous OP
You guys are right.
I tricked myself by putting a piece of tape on the torsion bar and drawing an arrow the direction of twist.
If you flip the bar end for end, the arrow changes direction.
What I didn't consider was that then the opposite end would do the twisting.
Thanks.
Re: torsion bar question #456692
09/01/09 09:46 PM
09/01/09 09:46 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
I recently took a pair out of a 69 b body for cleaning and they were installed with the L&R markings going into the LCA.
Re: torsion bar question [Re: repad] #456693
09/01/09 09:54 PM
09/01/09 09:54 PM
put the #'s/letters end at the rear so If you lose track of what you have in there you can eyeball it later & find out.
