shifter position on a833 od
#456180
09/01/09 12:14 AM
09/01/09 12:14 AM
Posts: 435 New Mexico
Scott440
New Mexico
Does the shifter position here look correct? I wanted to confirm before drilling holes in my new bracket.
Re: shifter position on a833 od
[Re: Cab_Burge]
#456184
09/01/09 08:47 AM
09/01/09 08:47 AM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
Years ago I bought a car that somebody had flipped the 3/4 lever back to it's normal orientation for a non OD unit... Can you imagine the look on my face when I unknowingly downshifted when I thought I was upshifting... at 6200 or so. Needless to say the motor had to come back out. I even remember thinking to myself how odd it was that fourth gear was smaller than third when inspecting the box. It's amazing how dangerous a few 17 year old kids can be with a Craftsman basic wrench and socket kit in mom and dad's garage! With all of that said, what is that setup going into? Has the trans had any work done to it?
[Re: Scott440]
#456186
09/01/09 11:30 AM
09/01/09 11:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Just thinking out loud but like the others have said it looks way to high.... I'm guessing you have about 3" of clearance from the trans to the tunnel and if thats the case your shifter would be up next to the seat. Also as stated if you put the arms level with the shifter arms it'll have a better leverage for the shift
[Re: Sixpak]
#456187
09/01/09 11:37 AM
09/01/09 11:37 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
That trans looks to me like one from a van. The tail housing has the dual mounting positions - forward position would be for a B Body, rearward for an E body. The van/truck application uses a plate unique to that use. Not sure if it would position the shifter for a pass car - even a B body.
Yes that is a pickup/van trans , the pickup used the forward mount with an adaptor (not sure if the van did also?) that raised it up and back and had it's own rods. Those look like B body NON OD rods , I can't see it working that well at that angle .
[Re: Jerry]
#456190
09/01/09 02:43 PM
09/01/09 02:43 PM
Posts: 4,285 Ohio
64dodge572
Ohio
That is going to be a mess in the E body. Way to far forward. It's not even a Hurst shifter, does it have ITM stamped on the side of the main housing? It would be best to use all stock E body 4-speed shifter and linkage and then modify the 3/4 rod to work with the flipped arm.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: Scott440]
#456191
09/01/09 06:23 PM
09/01/09 06:23 PM
Posts: 2,679 owt west
Thread Ender1
owt west
i just want to know if the rod position looks feasible. d100 truck trans/tailshaft; b/e body non-od links; going into an e-body car (but i will put a short shifter if needed so disregard height/car).
i dont think the a-body od links would work
Wow from the looks of that mess you might need to take a sledgehammer and swazall to the dash to be able to make your shifts.
