shifter position on a833 od #456180
09/01/09 12:14 AM
09/01/09 12:14 AM
New Mexico
Scott440 Offline OP
Scott440  Offline OP
New Mexico
Does the shifter position here look correct? I wanted to confirm before drilling holes in my new bracket.
Re: shifter position on a833 od [Re: Scott440] #456181
09/01/09 12:20 AM
09/01/09 12:20 AM
Is it going to be the height you want it in the car? it looks like it is higher than any stock shiters I've seen in A,B or E body cars
Re: shifter position on a833 od [Re: Cab_Burge] #456182
09/01/09 12:31 AM
09/01/09 12:31 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I don't know what your putting it in but the first thing I would do is turn the front 3-4 gear linkage arm so it face's up. Next thing you need is a bolt in the hole at the top of the shifter assembly . It's the main bolt for holding the shifter.
Re: shifter position on a833 od [Re: rowin4] #456183
09/01/09 12:42 AM
09/01/09 12:42 AM
the overdrive trannys come with the 3-4 arms reversed so third gear becomes overdrive when the shifter is in 4th gear position I have several of them and I'm thinking of reversing the reversed 3-4 arm so the gear shift lever will be in the third gear position when it is shifted into O.D., which will provide more room between the seats and the shifter which may also provide some entertaining conversations with some gear head passengers As far as the missing bolt, he is using a C clamp to hold the shifter and the mount in place before making the final decesion on the location, I think
Re: shifter position on a833 od [Re: Cab_Burge] #456184
09/01/09 08:47 AM
09/01/09 08:47 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Years ago I bought a car that somebody had flipped the 3/4 lever back to it's normal orientation for a non OD unit...
Can you imagine the look on my face when I unknowingly downshifted when I thought I was upshifting... at 6200 or so.
Needless to say the motor had to come back out. I even remember thinking to myself how odd it was that fourth gear was smaller than third when inspecting the box. It's amazing how dangerous a few 17 year old kids can be with a Craftsman basic wrench and socket kit in mom and dad's garage!
With all of that said, what is that setup going into? Has the trans had any work done to it?
Re: shifter position on a833 od [Re: Scott440] #456185
09/01/09 11:11 AM
09/01/09 11:11 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
First off, what chassis is that going into - B body, A body, etc? The shifter mounting position is relative to the opening in the floor, and that varies by the chassis type.
Have you done any floor tunnel modifications?
That trans looks to me like one from a van. The tail housing has the dual mounting positions - forward position would be for a B Body, rearward for an E body. The van/truck application uses a plate unique to that use. Not sure if it would position the shifter for a pass car - even a B body.
If it were my trans I'd want those shift rods parallel to the ground, like they are for a stock setup. That means lowering the location where the shifter mounts to the plate.
Big Block Dart has some tech stuff to where a guy made a plate to use that same trans in an A body. Might help with your build. He did however use the A body shift rods. It looks like your shift rods are the original ones from a van or truck application.
Re: shifter position on a833 od [Re: Scott440] #456186
09/01/09 11:30 AM
09/01/09 11:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just thinking out loud but like the others have said
it looks way to high.... I'm guessing you have about
3" of clearance from the trans to the tunnel and if
thats the case your shifter would be up next to the
seat.
Also as stated if you put the arms level with the shifter
arms it'll have a better leverage for the shift
Re: shifter position on a833 od [Re: Sixpak] #456187
09/01/09 11:37 AM
09/01/09 11:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes that is a pickup/van trans , the pickup used the forward mount with an adaptor (not sure if the van did also?) that raised it up and back and had it's own rods. Those look like B body NON OD rods , I can't see it working that well at that angle .
Re: shifter position on a833 od [Re: JohnRR] #456188
09/01/09 01:06 PM
09/01/09 01:06 PM
New Mexico
Scott440 Offline OP
Scott440  Offline OP
New Mexico
i just want to know if the rod position looks feasible. d100 truck trans/tailshaft; b/e body non-od links; going into an e-body car (but i will put a short shifter if needed so disregard height/car).
i dont think the a-body od links would work
Re: shifter position on a833 od [Re: Scott440] #456189
09/01/09 01:34 PM
09/01/09 01:34 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
you do know that ebodies use the rear shifter position on the tailshaft and not the front one. using that position will put the shifter way too far forward for you.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: shifter position on a833 od [Re: Jerry] #456190
09/01/09 02:43 PM
09/01/09 02:43 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
That is going to be a mess in the E body. Way to far forward. It's not even a Hurst shifter, does it have ITM stamped on the side of the main housing? It would be best to use all stock E body 4-speed shifter and linkage and then modify the 3/4 rod to work with the flipped arm.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: shifter position on a833 od [Re: Scott440] #456191
09/01/09 06:23 PM
09/01/09 06:23 PM
owt west
Thread Ender1 Offline
owt west
Wow from the looks of that mess you might need to take a sledgehammer and swazall to the dash to be able to make your shifts.
Re: shifter position on a833 od [Re: Thread Ender1] #456192
09/03/09 02:40 AM
09/03/09 02:40 AM
New Mexico
Scott440 Offline OP
Scott440  Offline OP
New Mexico
i have both an itm (came w/trans) and hurst (because itm isn't so good). i just picked up the itm because it has the shift arm already installed. i agree it's way too high and forward, i'll move it.
as for b position, it is in a highly modified race car where the engine sits well aft of the usual position..that's why i didn't want to focus on the application. it's also been in the car with the forward shift bolts and fore/aft position was not too bad. i'll see if lowering it gives the shifter more authority on the gearbox. as for the sawzall, thanks but i'll pass.
Re: shifter position on a833 od [Re: Scott440] #456193
09/03/09 09:33 PM
09/03/09 09:33 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Here's a post that might help.
Shifter
FRank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: shifter position on a833 od [Re: Chi_Town_Runner] #456194
09/04/09 01:35 AM
09/04/09 01:35 AM
New Mexico
Scott440 Offline OP
Scott440  Offline OP
New Mexico
thanks...i was just about to seek out some more installation pics. up to now, i had seen only how chevy trucks did it:
http://www.customclassictrucks.com/techa...n/photo_01.html
