late 72-74 Challenger vapor tank #455920
08/31/09 08:14 PM
08/31/09 08:14 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I've started cleaning up some of the smaller brakets and things from the Challenger. I dipped the vapor tank in EvapoRust since it was a crusty mess. It is looking a lot better but before I continue working on it I need to make sure it is still usable first.
Here is what I started with.
After sitting overnight. I assume the yellow is a chemical reaction with the EvapoRust and doesn't mean the tank was painted yellow from the factory.
What is inside these things? It sounds like there is a valve inside. I can here it when I move the tank from side to side. Also, I blocked all but one of the four tubes in front and blew compressed air into the tank. No air comes out of the 5th tube that goes up to the charcole canister.
I have a small pinhole in the top of the tank that I found today. It could be sealed up, but if there is a valve inside it that's junk I might as well look for a new one. Thanks
Re: late 72-74 Challenger vapor tank [Re: burdar] #455921
08/31/09 11:18 PM
08/31/09 11:18 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
that looks just like the one i pulled out of my 74 Challenger. it was all nasty and crusty too.
Re: late 72-74 Challenger vapor tank [Re: burdar] #455922
09/01/09 08:28 AM
09/01/09 08:28 AM
cataclysm80 Offline
cataclysm80  Offline
If you end up having to cut it open to find out what's inside, please post the results here so everyone else can learn too.
Tav
Re: late 72-74 Challenger vapor tank [Re: burdar] #455923
09/01/09 11:30 AM
09/01/09 11:30 AM
Jacksonville, FL
burnt_o_matic Offline
Jacksonville, FL
Good luck finding one of those new. I've been looking for years. You would think it would have been a service part, like the gas tank. If anyone has a lead on these, please post. Thanks.
Re: late 72-74 Challenger vapor tank [Re: burnt_o_matic] #455924
09/01/09 11:45 AM
09/01/09 11:45 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I thought maybe that most guys wouldn't even bother using them when putting thier cars back together. I was hoping someone would have a nice used one from down south.
