who runs a 588 and how fast do you go...........
#455804
08/31/09 06:39 PM
08/31/09 06:39 PM
Posts: 169 Nazareth,Pa.
JACKSON
Nazareth,Pa.
i just got my new megablock and 572-13 indy heads CNC'd not the biggest 572's heads, Callies crank, .789 cam motion roller cam, T & D rockers 1:7 ratio, msd crank trigger, ati balancer, jeff johnson billet oil pan, titan oil pump, indy 440-25 inline crossram , indy valley cover,with 2 edelbrock 800 carbs anybody out there run a similar combo, looking to find out what there best time. i remember seeing a few guys on here with this combo but cant seem to find out anything on this topic lately, any help thanks Larry
Re: who runs a 588 and how fast do you go...........
[Re: JACKSON]
#455805
08/31/09 09:18 PM
08/31/09 09:18 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
I don't run anythng near what you have but I want to some day With that said I'm guessing you are going to run some kind of 62-65 car in NSS and I have seen similar combo's to yours run anywhere from 9.20's to 9.70's depending on weight and set up. Get it real light and set up right and I can see very low 9's or better. Details on what you are putting it in and the balance of the combo would be nice (rear/converter/gears/size slicks and all) What are YOU expecting it to run? Russ
[Re: JACKSON]
#455806
08/31/09 09:19 PM
08/31/09 09:19 PM
Posts: 9,860 MI, usa
dvw
MI, usa
Lens 63 Plymouth that Gary Jacob drives has gone I believe 9.07@149. It ran mid 9.20@145 at the 131 Chrysler Classic. 3700lbs w/caltracks. I may be off on the numbers a little but they're close. I'm building a similar combo but with -1 heads. 15-1,.799 Comp 4/7 swap,1.7 T&D,Jessel,Indy X-Ram. Hopefully 3300lbs or a little less. I'm looking for similar results. Doug
[Re: dvw]
#455807
08/31/09 10:13 PM
08/31/09 10:13 PM
i have almost the same combo, now going low 9's with my new slicks 31 x10.5w x15 4.56 gears, ladder bar car now but went 9.29 with caltracs. 3317lb dodge coronet. what are you building, i live pretty close to you.
#455808
09/02/09 05:28 PM
09/02/09 05:28 PM
switching from 750 carters to 800 edelbrock carbs made no difference at all with the combo. im wondering going to a 8" converter from a 9.5 will hurt the combo?
[Re: Baxter61]
#455815
09/02/09 08:14 PM
09/02/09 08:14 PM
i know someone on here, who's got the slowest 588 wedge on the board. he wouldnt dare posting his information on here!
#455816
09/03/09 07:34 AM
09/03/09 07:34 AM
#455818
09/06/09 09:30 PM
09/06/09 09:30 PM
funny thing is that you are still scared to run us
maybe one day you will go a pair chrissy boy
Casey
#455819
09/06/09 10:19 PM
09/06/09 10:19 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Casey
What does "go a pair" mean??And while your at it,,,,,,,,What is "PROLLY"
Post deleted by Defbob
[Re: hemi-itis]
#455820
09/06/09 11:02 PM
09/06/09 11:02 PM
#455822
09/07/09 07:18 AM
09/07/09 07:18 AM
Casey
why dont you just answer cantwheelies question? wedgie boy! you do make 1000+ HP right? PROLLY AND I GO A PAIR
