Lockup converter, 97 Dodge 3.9 w/ 32RH
#455722
08/31/09 05:30 PM
08/31/09 05:30 PM
Posts: 1,712 NW Pa
DARTROD
NW Pa
Anyone know where the sensors are that control lockup? mine works intermittenly.
PROUD member of The Patriot Guard Riders
Re: Lockup converter, 97 Dodge 3.9 w/ 32RE
[Re: DARTROD]
#455723
08/31/09 06:35 PM
08/31/09 06:35 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
32RE? Ain't no such thing.
If it's a 32RH the lockup is controlled by the lockup valve spring.
[Re: John_Kunkel]
#455724
08/31/09 07:54 PM
08/31/09 07:54 PM
Posts: 1,712 NW Pa
DARTROD
NW Pa
It is a 32RH, the transmission itself shifts smooth, but sometimes the Converter doesn't lock up and it runs at a higher rpm.Can the spring or the valve be changed by itself to cure the problem?
