'70 Duster/A Body Rocker Panel Question #454776
08/30/09 05:47 PM
08/30/09 05:47 PM
Land of 10,000 Lakes
44D6PAKCUDA Online content OP
44D6PAKCUDA  Online Content OP
Is there normally a seam in the metal on the lower rocker panels on a '70 Duster? It lines up about the same area as the back edge of the door?Or if there is,it it normally "filled" in? Thanks for any info!
Re: '70 Duster/A Body Rocker Panel Question [Re: 44D6PAKCUDA] #454777
08/30/09 06:08 PM
08/30/09 06:08 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Yes there is a seam there.
It's the section where the 1/4 skin and rocker come together. The 1/4 wraps all the way under the rocker.
Re: '70 Duster/A Body Rocker Panel Question [Re: RobX4406] #454778
08/30/09 07:05 PM
08/30/09 07:05 PM
That's what I thought Rob,and thanks for the reply.I've seen 2 cars were they have both been filled in when doing the body work.Any chance you have a picture you could post or email me to show my body guy?
Re: '70 Duster/A Body Rocker Panel Question [Re: RobX4406] #454779
08/30/09 07:06 PM
08/30/09 07:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The factory used lead over those seams so you should not be able to see a visable joint.
Re: '70 Duster/A Body Rocker Panel Question [Re: Neil] #454780
08/30/09 07:14 PM
08/30/09 07:14 PM
Ahhhh,I thought it was visable.Goes to show you what I know about A Bodies....
Re: '70 Duster/A Body Rocker Panel Question [Re: 44D6PAKCUDA] #454781
08/30/09 07:51 PM
08/30/09 07:51 PM
Leetonia, OH
R6T8net Offline
R6T8net  Offline
Leetonia, OH
No seam but the factory lead job is quite noticeable however.
"Who is John Galt?"
68 Coronet RT LL1 Auto
70 Duster 340 (yea right) FE5 4 SPD, 11.86 @ 114 MPH so far
01 2500 Quad Cab 4x4 Cummins
