need help with one piece kickdown spring
#454691
08/30/09 03:53 PM
08/30/09 03:53 PM
Posts: 565 IA
landon1
IA
this photo is prior to rebuild - i just saw the darn thing, and now i can't find it anywhere. it runs from the throttle lever down to the kickdown/throttle cable bracket. is is just a safety spring for the factory return spring, or is it kickdown related? thanks EDIT: not the chrome double springs, i know what they are, i put them on with the new carb, but the lower spring, just for clarification, since you can see 3 springs in the picture
'71 Satellite Sebring 440
Re: what is this spring???
[Re: landon1]
#454692
08/30/09 04:04 PM
08/30/09 04:04 PM
Posts: 565 IA
landon1
IA
okay, after more digging, it's a kickdown spring - now how do i find out which one i had and where to get a new one?
[Re: Dougsmopars]
#454694
08/30/09 04:50 PM
08/30/09 04:50 PM
Posts: 565 IA
landon1
IA
that's what i was thinking...it's almost like a back-up throttle return spring, but i now have dual springs on the carb....during reassembly, i picked up the spring and had no idea how to hook it up to the point where it would work for kickdown - this picture is how it was hooked up when i got the car over 6 years ago... so i guess i now need to know how to hook up a kickdown spring on a one-piece kickdown linkage for a 440 any ideas?
[Re: aarcuda]
#454696
08/30/09 05:00 PM
08/30/09 05:00 PM
Posts: 565 IA
landon1
IA
not sure what you mean/where to connect - tried looking for pics, but can't seem to find any.
Re: need help with one piece kickdown spring
[Re: John_Kunkel]
#454699
08/30/09 07:25 PM
08/30/09 07:25 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
The pic below shows the correct one-piece linkage configuration, if you had the correct Holley throttle lever extension (Holley #20-7) you could eliminate the dogleg bend in the slotted link.
I copied the wrong pic over. Thanks John. The idea is the same to keep the rear of the slot in contact with the throttle at all times.
[Re: MoparforLife]
#454700
08/30/09 10:27 PM
08/30/09 10:27 PM
Posts: 565 IA
landon1
IA
well, i assume it's the chrysler throttle extension i have, i transferred it over from the holley that was on it. i got a great pic from a guy on the roadrunnernest, so now i can see exactly what i need to set it up like.
i also seem to have the "hillbilly" nut and bolt in the slot - i may have more questions on adjusting it later, but it seemed to work just fine.
[Re: landon1]
#454701
08/30/09 11:05 PM
08/30/09 11:05 PM
Posts: 15,491 the boonies
aarcuda
the boonies
thats how mine is
[Re: aarcuda]
#454702
08/30/09 11:09 PM
08/30/09 11:09 PM
Posts: 565 IA
landon1
IA
lol i know it, i've seen several like it...i just read it in another thread while doing a search
