need help with one piece kickdown spring #454691
08/30/09 03:53 PM
08/30/09 03:53 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
this photo is prior to rebuild - i just saw the darn thing, and now i can't find it anywhere. it runs from the throttle lever down to the kickdown/throttle cable bracket. is is just a safety spring for the factory return spring, or is it kickdown related?
thanks
EDIT: not the chrome double springs, i know what they are, i put them on with the new carb, but the lower spring, just for clarification, since you can see 3 springs in the picture
'71 Satellite Sebring 440
Re: what is this spring??? [Re: landon1] #454692
08/30/09 04:04 PM
08/30/09 04:04 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
okay, after more digging, it's a kickdown spring - now how do i find out which one i had and where to get a new one?
Re: what is this spring??? [Re: landon1] #454693
08/30/09 04:24 PM
08/30/09 04:24 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
kick down spring goes from the rear pivot to throttle stud. The one pictured is not a stock sping. From that pic it's hard to see how it is working as a kickdown spring
Re: what is this spring??? [Re: Dougsmopars] #454694
08/30/09 04:50 PM
08/30/09 04:50 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
that's what i was thinking...it's almost like a back-up throttle return spring, but i now have dual springs on the carb....during reassembly, i picked up the spring and had no idea how to hook it up to the point where it would work for kickdown - this picture is how it was hooked up when i got the car over 6 years ago...
so i guess i now need to know how to hook up a kickdown spring on a one-piece kickdown linkage for a 440 any ideas?
Re: what is this spring??? [Re: landon1] #454695
08/30/09 04:56 PM
08/30/09 04:56 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Connect it so it pulls the kd rod forward
Re: what is this spring??? [Re: aarcuda] #454696
08/30/09 05:00 PM
08/30/09 05:00 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
not sure what you mean/where to connect - tried looking for pics, but can't seem to find any.
Re: what is this spring??? [Re: landon1] #454697
08/30/09 05:45 PM
08/30/09 05:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Number 13 in this picture.
Re: need help with one piece kickdown spring [Re: landon1] #454698
08/30/09 06:31 PM
08/30/09 06:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pic below shows the correct one-piece linkage configuration, if you had the correct Holley throttle lever extension (Holley #20-7) you could eliminate the dogleg bend in the slotted link.
Re: need help with one piece kickdown spring [Re: John_Kunkel] #454699
08/30/09 07:25 PM
08/30/09 07:25 PM
Upper Midwest
Upper Midwest
I copied the wrong pic over. Thanks John. The idea is the same to keep the rear of the slot in contact with the throttle at all times.
Re: need help with one piece kickdown spring [Re: MoparforLife] #454700
08/30/09 10:27 PM
08/30/09 10:27 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
well, i assume it's the chrysler throttle extension i have, i transferred it over from the holley that was on it. i got a great pic from a guy on the roadrunnernest, so now i can see exactly what i need to set it up like.
i also seem to have the "hillbilly" nut and bolt in the slot - i may have more questions on adjusting it later, but it seemed to work just fine.
Re: need help with one piece kickdown spring [Re: landon1] #454701
08/30/09 11:05 PM
08/30/09 11:05 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
thats how mine is
Re: need help with one piece kickdown spring [Re: aarcuda] #454702
08/30/09 11:09 PM
08/30/09 11:09 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
lol i know it, i've seen several like it...i just read it in another thread while doing a search
Re: need help with one piece kickdown spring [Re: landon1] #454703
08/30/09 11:14 PM
08/30/09 11:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
First time I've looked at this thread, saw the first picture & thought "What a cobbled mess" then saw a few comment & your second picture... Looks much better..
Re: need help with one piece kickdown spring [Re: 1_WILD_RT] #454704
08/30/09 11:42 PM
08/30/09 11:42 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
have correct spring on order, so should be here in the coming week just in time for the new motor to burn some tires. when motor is back together i'll post pics in my project thread to show what it looks like. it's been a long process, upgrading things as i had money in high school and college, til i now finally had enough the pull the motor for rebuild, buy nice things, take my time, and get rid of the "cobbled-up mess" - much more better now!
