Help, I wanna run 10:30s #454675
08/30/09 03:32 PM
08/30/09 03:32 PM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
I just bought a 500" ,440 source stroker kit, 11to1, its going in a 66 Coronet with an 8" Turbo action converter, 4:30 gears 3200# car, what head, valve train combo would get me there? Be budget minded, Im not lookin to be cheap but not overkill either, thanks in advance
Re: Help, I wanna run 10:30s [Re: Thor500] #454676
08/30/09 03:49 PM
08/30/09 03:49 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Indy 440-1's
Re: Help, I wanna run 10:30s [Re: cudabunch] #454677
08/30/09 04:09 PM
08/30/09 04:09 PM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
who would you get the Indys through? I thought all their stuff needs to be gone through before you bolt em on. Cam? Roller?
Re: Help, I wanna run 10:30s [Re: Thor500] #454678
08/30/09 04:10 PM
08/30/09 04:10 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I have gone 10.26 so far,,,,with a 440 (.030) with ported Edelbrock heads,,,,and your car is lighter than mine by about 150 lbs.
plus i can use all my usual valve train stuff,,headers,,,etc,,,and stay low buck.
maybe the INDY EZ would be a step up from the E heads... ?
Re: Help, I wanna run 10:30s [Re: Thor500] #454679
08/30/09 04:42 PM
08/30/09 04:42 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
My last motor was 30 over 440 with nothing more than a 650 mech cam and 440-1 heads out of the box and 950 carb. It ran 10.40 @132 every pass shifting at 6000 rpm's i still run these same heads with a 1.91 valve and a 630 lift roller and its a little faster now.
Re: Help, I wanna run 10:30s [Re: 69CHARGERMD] #454680
08/30/09 06:04 PM
08/30/09 06:04 PM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
Who did you get the ported Edelbrocks from? 69CHARGERMD? What cam are you running?
Re: Help, I wanna run 10:30s [Re: Thor500] #454681
08/30/09 07:08 PM
08/30/09 07:08 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I don't quite agree that 440-1's would be budget minded. The Harland rockers cost more for the 440-1, I think an EZ headed combo with the Crane R280 roller would make a great combo, or ported super Victors.
I run the ported 440-1's on my 500" low deck, I'm getting it figured out but haven't been super impressed so far compared to my old 451 E-headed combo but that car was lighter and had a big tire.
Re: Help, I wanna run 10:30s [Re: ProSport] #454682
08/30/09 07:35 PM
08/30/09 07:35 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
My Edelbrocks were done by Dwayne Porter (board member here,,,),,,work is outstanding,,,highly recomend him.
Cam is a solid cam, comp cams, custom grind, ( not a roller ),,,
specs; 269/274 duration
640 lift
111 lobe
installed @ 109*
Flow on the heads per Dwayne are :
305.4 @ .700
303.6 @ .650
301.8 @ .600
etc,,,,
Car is low maintenence relatively speaking,,,
My goal is to get under the 10.20 range,,,as i work on my 60' times,,etc.
good luck,
Doug
Re: Help, I wanna run 10:30s [Re: 69CHARGERMD] #454683
08/30/09 08:41 PM
08/30/09 08:41 PM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
Thanks for the info Doug, sounds like the combo I'm lookin for.
Re: Help, I wanna run 10:30s [Re: Thor500] #454684
08/30/09 08:48 PM
08/30/09 08:48 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
On a side note...
The last time I asked Al_Aguire what I should do to consistantly run in the 10's... He told me to race 1/8th mile only..
