Windage Tray? #454648
08/30/09 02:50 PM
08/30/09 02:50 PM
MNobody Offline OP
MNobody  Offline OP
I'm going to build a 408 stroker and i've heard you don't need a windage tray? I'm going to try and modify a stock oil pan for more capacity or go aftermarket. Thanks.
Re: Windage Tray? [Re: MNobody] #454649
08/30/09 03:01 PM
08/30/09 03:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Most benifit from a tray.Its usually cheap ponys.Rocky
Chrysler Firepower
Re: Windage Tray? [Re: therocks] #454650
08/30/09 03:04 PM
08/30/09 03:04 PM
alabama
mopars rule Offline
mopar addict
mopars rule  Offline
mopar addict
alabama
When I put main studs on my smallblock I couldn't use the windage tray because the studs hit the pan. So I got a screen for the pan and put on a dual crankscraper. I believe there is power to be gained by keepin down the drag on the crank.
Re: Windage Tray? [Re: MNobody] #454651
08/30/09 04:04 PM
08/30/09 04:04 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
I've used a windage tray with a 8 qt. milodon pan and saw no difference with or without it, however I never ran 8 qts. I usually run 6 qts. A good street strip oil pan is a Kevco and it hold 6 qts and has a scraper and doors and is under $200.00 IIRC
Re: Windage Tray? [Re: mopars rule] #454652
08/30/09 05:15 PM
08/30/09 05:15 PM
Many SB NHRA stock class racers don't use a windage tray but most of them do use a scraper and a one way wire baffle.
Re: Windage Tray? [Re: Cab_Burge] #454653
08/30/09 07:25 PM
08/30/09 07:25 PM
MNobody Offline OP
MNobody  Offline OP
Thanks for the info
Re: Windage Tray? [Re: MNobody] #454654
08/30/09 09:10 PM
08/30/09 09:10 PM
Locomotion Offline
Locomotion  Offline
I'm using a scraper from this source:
Ihihara-Johnson Crank Scrapers
