Why does my car stumble in the air?
#454577
08/30/09 02:26 PM
08/30/09 02:26 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
Would it help to put jet extenstions on? Carbs are sideways. Fuel pressure is 6 1/2 an use 4 port magna fuel. Or just maybe set the floats little higher? An thoughts? Thanks
Shawn Jennings
Re: Why does my car stumble in the air?
[Re: 408strokerdart]
#454579
08/30/09 02:45 PM
08/30/09 02:45 PM
572_dup2
Salina ks
It does it on every pass just before i shift into 2nd. If it did it once or twice maybe think its a fluck. Do you think fuel pressure needs turned up too?
Shawn Jennings
[Re: Al_Alguire]
#454582
08/30/09 03:12 PM
08/30/09 03:12 PM
572_dup2
Salina ks
Best 60's ever all 1.28s. Got the bump stops set as tight as im gunna set them. Leaves the best around 2000rpm. Sounds like an feels like its starved for fuel right before 2nd an then after i shift it takes it a little time to recover. I have video i will show as soon as the get it to me.
Shawn Jennings
Post deleted by Defbob
[Re: 572_dup2]
#454583
08/30/09 03:36 PM
08/30/09 03:36 PM
#454584
08/30/09 03:39 PM
08/30/09 03:39 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
What fuel pump are you using and is there a air filter on the carbs ?
[Re: 572_dup2]
#454585
08/30/09 03:59 PM
08/30/09 03:59 PM
[Re: 572_dup2]
#454587
08/30/09 04:13 PM
08/30/09 04:13 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
standard floats will close the needle and seat when fuel sloshes back
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: MegaDart]
#454589
08/30/09 04:29 PM
08/30/09 04:29 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
How long and high is it in the air? Maybe it is possible you are up long and high enough to uncover the front jets in carb long enough to cause and issue. Maybe some sort of modified jet extensions are in order? Have you watched the fuel pressure to see what it is doing? I know that is easier said than done while driving a car in the air but might take a peak.
[Re: Al_Alguire]
#454590
08/30/09 04:58 PM
08/30/09 04:58 PM
572_dup2
Salina ks
Dont think its a voltage thing. Im back to 2 battires now.
Fuel pressure in high gear is around 6 61/4. But it dont now what fuel pressure is off the line?
Im going to cut 2 holes in the front of the cowl to let some air in. Its a piece of trash in high gear. Runs less MPH than it did before, but the 60' is best 1/8 mph is up some an 1/8 et is getting better. This should fell like afterburners kicking in!
Shawn Jennings
[Re: 572_dup2]
#454592
08/30/09 05:17 PM
08/30/09 05:17 PM
Posts: 20,169 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Shawn how close are your carbs to the top of your hood scoop? I had to take my tunnel ram off because mine were to close and would shut off air flow to the carbs.
[Re: Cab_Burge]
#454593
08/30/09 05:17 PM
08/30/09 05:17 PM
572_dup2
Salina ks
could be possible? But we didnt see any sign of fuel coming out? It fells like it starts this when the car is at its highest. But it happens so fast sometimes i forget. LOL
Im hoping the video shows signs of whats happening.
Shawn Jennings
[Re: 572_dup2]
#454597
08/30/09 08:55 PM
08/30/09 08:55 PM
had the same problem today, my car was leaving hard and pulling up the frontend causing my jets to be uncovered causing a lean condition. i raised my floats up on both carbs a bunch with a drill bit and problem solved. got my best et ever in bad air. dont touch your fuel psi, thats not your problem.
#454598
08/30/09 09:00 PM
08/30/09 09:00 PM
jet extentions wont help with sideways carbs.
#454599
08/30/09 09:21 PM
08/30/09 09:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A set of 90% bent tubes would so the ends are at the rear of the carb(what is the rear now)... might be able to use a short piece of fuel hose to connect them to the jets.... I'd do all of the jets to make sure they are all getting fuel. This should work for a test and if it corrects the problem then I'd make up something that would be a little more permanent. Also the comment of being slower in high gear... it could be a air issue... put a air pan on first that may knock out some of the hot air thats up in the cowl(thats where its trying to escape to)
[Re: hemi-itis]
#454602
08/30/09 09:39 PM
08/30/09 09:39 PM
MR_P_BODY
To eliminate the hood as an issue,make a pass without the hood on
I believe he did(in his hood post) and really slowed
[Re: hemi-itis]
#454603
08/30/09 09:41 PM
08/30/09 09:41 PM
572_dup2
Salina ks
slowed down when i took the hood off.
Shawn Jennings
[Re: 572_dup2]
#454604
08/30/09 09:55 PM
08/30/09 09:55 PM
MR_P_BODY
Shawn, you might want to try larger needle and seats on the carbs(might need to go to the alky seats for more flow
[Re: Chris'sBarracuda]
#454609
08/30/09 11:50 PM
08/30/09 11:50 PM
Posts: 307 OH
TheBlackCar
OH
The first thing I would do is make a pass with the hood off..
Chris..
Taking the hood off of something fast usually has a negative affect because fuel is pulled out of carb and ends up on the windshield. Not to mention what it does to the air...
#454610
08/31/09 07:31 AM
08/31/09 07:31 AM
Posts: 9,994 Frostbitefalls MN (Rocky&Bullw...
gregsdart
They will if they are made to draw from further back in the bowl, and that was my idea, and I believe Als as well. It would take some custom work, as they would need to be flattened a little to allow for ending in the middle of the bowl instead of straight out from the jet. A little tubing, a torch, a (small!)hammer, and problem solved.
[Re: Al_Alguire]
#454612
08/31/09 11:23 AM
08/31/09 11:23 AM
[Re: gregsdart]
#454614
08/31/09 01:09 PM
08/31/09 01:09 PM
[Re: DJVCuda]
#454616
08/31/09 01:24 PM
08/31/09 01:24 PM
[Re: DJVCuda]
#454618
08/31/09 03:19 PM
08/31/09 03:19 PM
MR_P_BODY
I would think the front jets(front now) could uncover and its easier to suck air than it is fuel.... but then again it could be a air issue going into the carbs..... or just lack of fuel
