Page 1 of 3 1 2 3
Why does my car stumble in the air? #454577
08/30/09 02:26 PM
08/30/09 02:26 PM
Salina ks
572_dup2 Offline OP
Back On The Bumper!!
572_dup2  Offline OP
Salina ks
Would it help to put jet extenstions on? Carbs are sideways. Fuel pressure is 6 1/2 an use 4 port magna fuel. Or just maybe set the floats little higher? An thoughts?
Shawn Jennings
Re: Why does my car stumble in the air? [Re: 572_dup2] #454578
08/30/09 02:32 PM
08/30/09 02:32 PM
Out West
408strokerdart Offline
Out West
Not sure jet extensions will help, but you might be able to cure some of the problem with raising the floats some?
Re: Why does my car stumble in the air? [Re: 408strokerdart] #454579
08/30/09 02:45 PM
08/30/09 02:45 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
It does it on every pass just before i shift into 2nd. If it did it once or twice maybe think its a fluck. Do you think fuel pressure needs turned up too?
Shawn Jennings
Re: Why does my car stumble in the air? [Re: 572_dup2] #454580
08/30/09 02:50 PM
08/30/09 02:50 PM
Q
Quicktree Offline
Quicktree  Offline
Q
turn the fuel pressure up to 8 at idle. and check the bowl level
Re: Why does my car stumble in the air? [Re: Quicktree] #454581
08/30/09 03:03 PM
08/30/09 03:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Calm down the wheelstand, I know that is not what you want to hear but it is probably the RIGHT way
Re: Why does my car stumble in the air? [Re: Al_Alguire] #454582
08/30/09 03:12 PM
08/30/09 03:12 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Best 60's ever all 1.28s. Got the bump stops set as tight as im gunna set them. Leaves the best around 2000rpm. Sounds like an feels like its starved for fuel right before 2nd an then after i shift it takes it a little time to recover.
I have video i will show as soon as the get it to me.
Shawn Jennings
Post deleted by Defbob [Re: 572_dup2] #454583
08/30/09 03:36 PM
08/30/09 03:36 PM
Re: Why does my car stumble in the air? #454584
08/30/09 03:39 PM
08/30/09 03:39 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
What fuel pump are you using and is there a air filter on the carbs ?
Post deleted by Defbob [Re: 572_dup2] #454585
08/30/09 03:59 PM
08/30/09 03:59 PM
Re: Why does my car stumble in the air? #454586
08/30/09 04:04 PM
08/30/09 04:04 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Magna Fuel 500
Shawn Jennings
Re: Why does my car stumble in the air? [Re: 572_dup2] #454587
08/30/09 04:13 PM
08/30/09 04:13 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
standard floats will close the needle and seat when fuel sloshes back
Re: Why does my car stumble in the air? [Re: 572_dup2] #454588
08/30/09 04:14 PM
08/30/09 04:14 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
a voltage drop can slow you fuel pump down too
Re: Why does my car stumble in the air? [Re: MegaDart] #454589
08/30/09 04:29 PM
08/30/09 04:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
How long and high is it in the air? Maybe it is possible you are up long and high enough to uncover the front jets in carb long enough to cause and issue. Maybe some sort of modified jet extensions are in order? Have you watched the fuel pressure to see what it is doing? I know that is easier said than done while driving a car in the air but might take a peak.
Re: Why does my car stumble in the air? [Re: Al_Alguire] #454590
08/30/09 04:58 PM
08/30/09 04:58 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Dont think its a voltage thing. Im back to 2 battires now.
Fuel pressure in high gear is around 6 61/4. But it dont now what fuel pressure is off the line?
Im going to cut 2 holes in the front of the cowl to let some air in. Its a piece of trash in high gear. Runs less MPH than it did before, but the 60' is best 1/8 mph is up some an 1/8 et is getting better. This should fell like afterburners kicking in!
Shawn Jennings
Re: Why does my car stumble in the air? [Re: 572_dup2] #454591
08/30/09 05:12 PM
08/30/09 05:12 PM
Is it possible that fuel is sloshing into the carbs form the vents? I had that problem with my six pak and didn't realise it for a long time
Re: Why does my car stumble in the air? [Re: 572_dup2] #454592
08/30/09 05:17 PM
08/30/09 05:17 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Shawn how close are your carbs to the top of your hood scoop? I had to take my tunnel ram off because mine were to close and would shut off air flow to the carbs.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Why does my car stumble in the air? [Re: Cab_Burge] #454593
08/30/09 05:17 PM
08/30/09 05:17 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
could be possible? But we didnt see any sign of fuel coming out? It fells like it starts this when the car is at its highest. But it happens so fast sometimes i forget. LOL
Im hoping the video shows signs of whats happening.
Shawn Jennings
Re: Why does my car stumble in the air? [Re: 572_dup2] #454594
08/30/09 05:22 PM
08/30/09 05:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Injection will take care of it, Think what it'll look like with stacks sticking thru the hood!
Re: Why does my car stumble in the air? [Re: 572_dup2] #454595
08/30/09 05:26 PM
08/30/09 05:26 PM
I think the fuel in the carbs. is held down by gravity while the car is going up and once it starts to slow down going up the fuel will be released from the graivity and rise up in the fuel bowls and possibly slosh out thru the vents I used three peices of rubber hose and routed it to the rear of the air cleaner base, on my tunnel rams I'm going to use two vacume tees per carb and hook them onto the vents with a short piece of hose and connect the vents in line and leave the ends open on both ends. I should make one up and take a picture and post that instead of trynig to describe it in words
Re: Why does my car stumble in the air? [Re: Al_Alguire] #454596
08/30/09 06:02 PM
08/30/09 06:02 PM
gregsdart Online content
gregsdart  Online Content
Look at the highest angle you get the car up to, then add about thirty degrees for acceleration, maybe more. Look at a float bowl at that angle and you can see what is happening to the fuel. I bet the custom jet extensions will do it.
Page 1 of 3 1 2 3
