Page 2 of 3 1 2 3
Re: Why does my car stumble in the air? [Re: 572_dup2] #454597
08/30/09 08:55 PM
08/30/09 08:55 PM
Best 60's ever all 1.28s. Got the bump stops set as tight as im gunna set them. Leaves the best around 2000rpm. Sounds like an feels like its starved for fuel right before 2nd an then after i shift it takes it a little time to recover.
I have video i will show as soon as the get it to me.
had the same problem today, my car was leaving hard and pulling up the frontend causing my jets to be uncovered causing a lean condition.
i raised my floats up on both carbs a bunch with a drill bit and problem solved. got my best et ever in bad air.
dont touch your fuel psi, thats not your problem.
Re: Why does my car stumble in the air? #454598
08/30/09 09:00 PM
08/30/09 09:00 PM
jet extentions wont help with sideways carbs.
Re: Why does my car stumble in the air? #454599
08/30/09 09:21 PM
08/30/09 09:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A set of 90% bent tubes would so the ends are at the
rear of the carb(what is the rear now)... might be
able to use a short piece of fuel hose to connect
them to the jets.... I'd do all of the jets to make
sure they are all getting fuel. This should work for
a test and if it corrects the problem then I'd make up
something that would be a little more permanent.
Also the comment of being slower in high gear...
it could be a air issue... put a air pan on first
that may knock out some of the hot air thats up in
the cowl(thats where its trying to escape to)
Re: Why does my car stumble in the air? [Re: MR_P_BODY] #454600
08/30/09 09:27 PM
08/30/09 09:27 PM
Arizona
Chris'sBarracuda Offline
Arizona
The first thing I would do is make a pass with the hood off..
Chris..
Re: Why does my car stumble in the air? [Re: MR_P_BODY] #454601
08/30/09 09:30 PM
08/30/09 09:30 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
To eliminate the hood as an issue,make a pass without the hood on
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Why does my car stumble in the air? [Re: hemi-itis] #454602
08/30/09 09:39 PM
08/30/09 09:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe he did(in his hood post) and really slowed
Re: Why does my car stumble in the air? [Re: hemi-itis] #454603
08/30/09 09:41 PM
08/30/09 09:41 PM
Salina ks
572_dup2 Offline OP
Back On The Bumper!!
572_dup2  Offline OP
Salina ks
slowed down when i took the hood off.
Shawn Jennings
Re: Why does my car stumble in the air? [Re: 572_dup2] #454604
08/30/09 09:55 PM
08/30/09 09:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Shawn, you might want to try larger needle and seats
on the carbs(might need to go to the alky seats for
more flow
Re: Why does my car stumble in the air? [Re: MR_P_BODY] #454605
08/30/09 09:58 PM
08/30/09 09:58 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
more flow
Great idea!! Never thought of that. Im calling holley tech tomorrow an i will ask that question also.
Shawn Jennings
Re: Why does my car stumble in the air? *DELETED* *DELETED* [Re: 572_dup2] #454606
08/30/09 09:58 PM
08/30/09 09:58 PM
San Jose Ca.
boatracer572 Online content
boatracer572  Online Content
San Jose Ca.
Post deleted by boatracer572
Re: Why does my car stumble in the air? [Re: boatracer572] #454607
08/30/09 10:00 PM
08/30/09 10:00 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Thanks Boatracer572!
Shawn Jennings
Re: Why does my car stumble in the air? [Re: 572_dup2] #454608
08/30/09 11:46 PM
08/30/09 11:46 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Angled floats. Put a bolt w/ jam nut in each carb so motor doesn't pull scoop down.
Good Luck
Re: Why does my car stumble in the air? [Re: Chris'sBarracuda] #454609
08/30/09 11:50 PM
08/30/09 11:50 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Chris..
Taking the hood off of something fast usually has a negative affect because fuel is pulled out of carb and ends up on the windshield. Not to mention what it does to the air...
Re: Why does my car stumble in the air? #454610
08/31/09 07:31 AM
08/31/09 07:31 AM
gregsdart Offline
gregsdart  Offline
They will if they are made to draw from further back in the bowl, and that was my idea, and I believe Als as well. It would take some custom work, as they would need to be flattened a little to allow for ending in the middle of the bowl instead of straight out from the jet. A little tubing, a torch, a (small!)hammer, and problem solved.
Re: Why does my car stumble in the air? [Re: gregsdart] #454611
08/31/09 10:10 AM
08/31/09 10:10 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Post deleted by Defbob [Re: Al_Alguire] #454612
08/31/09 11:23 AM
08/31/09 11:23 AM
Re: Why does my car stumble in the air? #454613
08/31/09 11:33 AM
08/31/09 11:33 AM
gregsdart Offline
gregsdart  Offline
is it even possible to uncover a jet on side mounted carbs ? maybe nearly straight up if at all
From the looks of your avitar, I would say YES!
Post deleted by Defbob [Re: gregsdart] #454614
08/31/09 01:09 PM
08/31/09 01:09 PM
Re: Why does my car stumble in the air? #454615
08/31/09 01:14 PM
08/31/09 01:14 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
i saw that ( fred ) from the stands - he never had any hesitation, from his foot or the carbs - he dragged the bumper a couple hundred feet - and its safe to say the OP cant uncover the jets -
Post deleted by Defbob [Re: DJVCuda] #454616
08/31/09 01:24 PM
08/31/09 01:24 PM
Page 2 of 3 1 2 3
