Re: Small Block goes 6.99@199
[Re: dodge beast]
#453959
08/31/09 06:25 PM
08/31/09 06:25 PM
Posts: 83 VA.
Avenger
VA.
AVENGER, AWESOME run. Maybe you could give me some info/help. I have been trying to get my SB to run on blowthru carb/alcohol with a F2 procharger @ 16lbs boost and can't get enough fuel to motor on top end. Carb is a custom built Carb Shop blowthru with dual inlets frt/rear, same regulator as U. I tried a Magna Fuel 500 electric pump. What type of fuel pump are u using and how much carb jetting @ what Boost?? Any help would be greatly appreciated, Thanx.
I don't think that pump and carb setup is going to give you enough fuel. I might work with gas but not methanol. I probably need more info on that before making that decision. I'm running the aeromotive Billet Belt Drive Pump. My jetting is up to around .189
PM me some more info on the combination and I will see if I can recommend something.
[Re: MegaDart]
#453960
08/31/09 06:32 PM
08/31/09 06:32 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
[Re: Darrell]
#453966
09/04/09 09:16 PM
09/04/09 09:16 PM
Posts: 83 VA.
Avenger
VA.
Awsome job Bill! I know the VMP crowd enjoyes seeing you run! How bout you and Lonnie Johnson doing some passes side by side!!!! I think you will take him!
Thanks Darrell, I enjoy running at VMP. I owe the fans another race there which they will get on September 19 and 20 at the Small Motor Nationals. I broke my trans running Lonnie there. Exploded it when I pulled 2nd gear. Would have been a good race. He is a class act! I would like to go against him again at VMP. I wanted to see if he would come to the OSBA Small Motor Nationals on September 19th and 20th. That is one tough Hemi! I wish more Mopar Guys would come out and have a good time!
[Re: Chad Bittle]
#453970
09/05/09 09:54 AM
09/05/09 09:54 AM
Posts: 83 VA.
Avenger
VA.
Well damnit, so much for having the badest Avenger, haha.
Very awesome, man. No other way to put it.
Thanks Chad, one mopar never takes away from another...you still have the baddest Avenger. Which do you have?
[Re: Avenger]
#453971
09/06/09 10:36 PM
09/06/09 10:36 PM
Posts: 687 Ohio
Chad Bittle
Ohio
Not even close to being done, just saving up and paying as we go. But the plan is to build a 10.00 street/strip Avenger with a 440 and most of the interior still in it.
[Re: wheelsup68dart]
#453973
09/13/09 09:45 AM
09/13/09 09:45 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
Just Freekin Awesome!!! Gives me something to look forward too and see that my expectations aren't too far fetched. I have a 468cui W9-RP with Twin 76's going together (Fuel Injected)Going in a '99 Dakota that is currently having a full tube Chassis put in it. Expecting to get it down to 2600-2800lbs and looking at hit 8.00 sec consistently. Thanks for the Inspiration. ![](/ubbthreads/images/graemlins/2491406-danstruck.gif)
[Re: Avenger]
#453975
09/13/09 09:16 PM
09/13/09 09:16 PM
Posts: 345 iowa
wesw
iowa
nice pass and a small block also. ![](/ubbthreads/images/graemlins/thumbs.gif) i can't wait to get my new engine in my avenger.
598 ci predator
[Re: MIKES_DUSTER]
#453976
09/15/09 01:12 AM
09/15/09 01:12 AM
Posts: 83 VA.
Avenger
VA.
What a BEAUTIFUL and FAST Avenger!!!! Is that Bill Mays old car??
Thanks Mike. Chris Rini out of NY owned the car before me. He now runs the ATI sponsored Stratus.
[Re: Avenger]
#453977
09/15/09 02:14 AM
09/15/09 02:14 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Nice job Bill!! Your runs with the car are Awesome, mike ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Avenger]
#453978
09/15/09 09:46 AM
09/15/09 09:46 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Didn't Chris's brother go for a plane ride on the Hudson river?
