What would you run? #453579
08/29/09 05:29 PM
08/29/09 05:29 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
Good afternoon guys, I usually hang out on the other forums, but I had a question that was best suited for ya'll. My old race buddy called me and ask me what cam he should run in his motor. It has been so many years since I have played in that arena that I am not up to date. He wants a hydralic roller for "street" use. He is what I know about the set up.
Its a 73 Challenger
Engine
440 30 over
906 heads seriously ported by Bob Stape (I use to use these to run 10s in various bodies)
496 stroker stroke
BME rods
10.5-11 Ross pistons
Trantula intake w/ a dominator flange grafted in and flowed and ported by Bob
and a BG Dominator 1150 or 1350
Trans
727
manual reverse Cheetah VB
low first gear and "hemi" drums
3500 stall
Rear is a 8.75 w/ 391s
Suspansion
SS springs
Frame connectors
Stock front end with fresh poly bushings.
His purpose is to have a nice cruiser that will not run hot and can takes 100 mile (distant not per hour) drives and of course go as face as humanly possible.
So what would you suggest-specs and name brand
Thanks in advance, Kevin
Careful, your character's showing!
Re: What would you run? [Re: mopar346] #453580
08/29/09 09:36 PM
08/29/09 09:36 PM
mopar346 Offline OP
mopar346  Offline OP
No suggestion???? on the cam that is.
Re: What would you run? [Re: mopar346] #453581
08/30/09 07:58 AM
08/30/09 07:58 AM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
I would suggest a call to Scott Brown of Straightline Performance, and ask him.
Someone here will have his contact info.
Good Luck
codfish
Re: What would you run? [Re: codfish] #453582
08/30/09 10:42 AM
08/30/09 10:42 AM
Colorado
506RR Offline
506RR  Offline
Colorado
Dwayne Porter at Porter Racing Heads would also be a great person to call. He will be able to set you up with the right cam! His username is fast68plymouth here on the board.
Good Luck with it!
Re: What would you run? [Re: 506RR] #453583
08/30/09 02:15 PM
08/30/09 02:15 PM
WA 98043
thecarfarmer Offline
WA 98043
X2 on Dwayne; I haven't used his services, but his reputation is A-#1. I've talked to him on the phone and he seems as good a guy as everyone says.
Other options (as if you needed 'em) would be Mike Jones, or Harold who designed a bunch of the older Ultradyne stuff ( brookshire@panola.com) who are both real active on the speedtalk forum.
I'd expect any of these guys could get you where you want to go.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: What would you run? [Re: thecarfarmer] #453584
08/30/09 09:52 PM
08/30/09 09:52 PM
mopar346 Offline OP
mopar346  Offline OP
Thanks guys, I'll follow up with these folks and try to post their responses.
