Good afternoon guys, I usually hang out on the other forums, but I had a question that was best suited for ya'll. My old race buddy called me and ask me what cam he should run in his motor. It has been so many years since I have played in that arena that I am not up to date. He wants a hydralic roller for "street" use. He is what I know about the set up.
Its a 73 Challenger
Engine
440 30 over
906 heads seriously ported by Bob Stape (I use to use these to run 10s in various bodies)
496 stroker stroke
BME rods
10.5-11 Ross pistons
Trantula intake w/ a dominator flange grafted in and flowed and ported by Bob
and a BG Dominator 1150 or 1350
Trans
727
manual reverse Cheetah VB
low first gear and "hemi" drums
3500 stall
Rear is a 8.75 w/ 391s
Suspansion
SS springs
Frame connectors
Stock front end with fresh poly bushings.
His purpose is to have a nice cruiser that will not run hot and can takes 100 mile (distant not per hour) drives and of course go as face as humanly possible.
So what would you suggest-specs and name brand
Thanks in advance, Kevin
Careful, your character's showing!
