Wheel Screws Question #453505
08/29/09 04:17 PM
08/29/09 04:17 PM
Arizona
Chris'sBarracuda Offline OP
Arizona
Just checking... :shruggy
I just got some new tires and wheels. 15"x 14" wheel with a 14x32 tire M/T 3074S.
I have been seeing alot more cars WITHOUT wheel screws.
Just wondering if it is still good to use screws any more or has tire tech gotten so much better that it is not needed?
I used to run about 16 screws on each side of the wheel, using a drill press to make sure they were spaced correctly.
I just got my new wheels and don't want to drill holes in them if it isn't necessary..
But I'm fairly sure I will have to..
I'll be using the car for S/C-S/G-S/ST racing.
What's everyone's take on this??
I've looked at some of the SS/AH cars and some DO NOT have screws..
Chris..
Re: Wheel Screws Question [Re: Chris'sBarracuda] #453506
08/29/09 04:48 PM
08/29/09 04:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
do a search, there was just a very long thread on this subject
Re: Wheel Screws Question [Re: Quicktree] #453507
08/29/09 05:03 PM
08/29/09 05:03 PM
Arizona
Arizona
thanks Tony..
Found it..
Chris..
Re: Wheel Screws Question [Re: Chris'sBarracuda] #453508
08/29/09 05:14 PM
08/29/09 05:14 PM
going 9.20 without screws, id hate to see those beauties drilled if dont have to.
Re: Wheel Screws Question #453509
08/29/09 07:28 PM
08/29/09 07:28 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I would say depends a lot on if you are running tubes or not I would not run tubes without them being screwed if you do and the tire slips it will rip the valve stem out of the tube.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Wheel Screws Question [Re: dusturbd340W5] #453510
08/29/09 07:43 PM
08/29/09 07:43 PM
dont run a rim screwless with tubes.
Re: Wheel Screws Question #453511
08/29/09 07:43 PM
08/29/09 07:43 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I got some new slicks and was wondering the same thing. Those are pretty cool rims, Chris! Who makes 'em? I'm always looking for different wheels, my car will just have some boring Pro Stars . I'm kinda stuck with Weld, because of the BS...and i need a street/strip wheel.
Re: Wheel Screws Question [Re: B1Fish540] #453512
08/29/09 07:49 PM
08/29/09 07:49 PM
boring pro stars!!
Re: Wheel Screws Question #453513
08/29/09 07:54 PM
08/29/09 07:54 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
boring pro stars!!
rut roh...i mean "the very popular" Pro Stars... and attractive!
Re: Wheel Screws Question [Re: B1Fish540] #453514
08/29/09 08:09 PM
08/29/09 08:09 PM
408Dust Offline
408Dust  Offline
Depends on the tire, I had Goodyears&Hoosiers that never moved but the Mickey's did. Try it without screws but be prepared to install them if they do.
Re: Wheel Screws Question [Re: 408Dust] #453515
08/29/09 08:26 PM
08/29/09 08:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To me it truly would be a couple of factors, if you
run tubes... its a must... and second be be the tire
pressure... if you run low tire pressure its not much
holding the tire to the wheel and if you get sideways
its easy to pop the bead free
Re: Wheel Screws Question [Re: Chris'sBarracuda] #453516
08/29/09 08:36 PM
08/29/09 08:36 PM
Cab_Burge Online work
Cab_Burge  Online Work
Are you going to run bias ply or radails? I haven't ran rim screws in any of my cars in over twenty years, all of my rear tires are mounted tubeless. I do put a small dab of white shoe polish on the edge of the rim and tire bead and watch it, usually moves about a inch and stops
Re: Wheel Screws Question [Re: Cab_Burge] #453517
08/30/09 07:45 AM
08/30/09 07:45 AM
Arizona
Arizona
The Wheels are Centerline Qualifier wheels.
Back when I was a youngster I worked there and still am friends with the VP there. He took good care of me.
I will be running tubeless. Have done it this way for years now.
I have just seen so many cars WITHOUT screws lately, that I was afraid I was missing something.
These are 14x32 stiff sidewall for Super Class racing.
Gecker always had me put 16 screws per side-32 per wheel.
I only put 12 on my last set.
But what He has taught me about the number of screws in the wheel.... When the tire wrinkles, it will put as many wrinkles as there are screws... Therefore, the more screws, the more wrinkles---but they are smaller...And fewer screws mean less wrinkles and larger..
In this picture I'm posting you can see what I mean. The wrap of the tire starts at the screw, and travels outward.
So.. If more screws are used and the wrap up is tighter, will the tire be stiffer?
These are some of the questions I have floating around..
Chris..
Re: Wheel Screws Question [Re: Chris'sBarracuda] #453518
08/30/09 11:36 AM
08/30/09 11:36 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
We did testing a few years back and on a big tire car with lots of torque that is correct as the smaller wrinkles help maintain the tire shape and contact patch. I don't think you will see that as much on smaller tire, higher pressure, lower powered cars.
Re: Wheel Screws Question [Re: Chris'sBarracuda] #453519
08/30/09 01:03 PM
08/30/09 01:03 PM
Tucson, Arizona
johnnyrotten Offline
Tucson, Arizona
You need to tighten the screw in the drivers seat!
Re: Wheel Screws Question [Re: johnnyrotten] #453520
08/30/09 09:34 PM
08/30/09 09:34 PM
Arizona
Arizona
But what if that was YOU...
BTW Brian took my front clip last night to fix it.
Chris..
Re: Wheel Screws Question [Re: Chris'sBarracuda] #453521
08/30/09 11:55 PM
08/30/09 11:55 PM
Tucson, Arizona
Tucson, Arizona
I haven't heard anything about driving your ride in a while. I thought you and Bildo were like usual!!
Re: Wheel Screws Question [Re: johnnyrotten] #453522
08/31/09 02:14 AM
08/31/09 02:14 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Why not just turn loose of some cash and go the beadlock route...Sure looks Cool too
