Wheel Screws Question
#453505
08/29/09 04:17 PM
08/29/09 04:17 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Just checking... :shruggy I just got some new tires and wheels. 15"x 14" wheel with a 14x32 tire M/T 3074S. I have been seeing alot more cars WITHOUT wheel screws. Just wondering if it is still good to use screws any more or has tire tech gotten so much better that it is not needed? I used to run about 16 screws on each side of the wheel, using a drill press to make sure they were spaced correctly. I just got my new wheels and don't want to drill holes in them if it isn't necessary.. ![](/ubbthreads/images/graemlins/laugh2.gif) But I'm fairly sure I will have to.. I'll be using the car for S/C-S/G-S/ST racing. What's everyone's take on this?? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I've looked at some of the SS/AH cars and some DO NOT have screws.. ![](/ubbthreads/images/graemlins/confused.gif) Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
Re: Wheel Screws Question
[Re: Chris'sBarracuda]
#453508
08/29/09 05:14 PM
08/29/09 05:14 PM
going 9.20 without screws, id hate to see those beauties drilled if dont have to. ![](/ubbthreads/images/graemlins/thumbs.gif)
#453509
08/29/09 07:28 PM
08/29/09 07:28 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I would say depends a lot on if you are running tubes or not I would not run tubes without them being screwed if you do and the tire slips it will rip the valve stem out of the tube.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#453510
08/29/09 07:43 PM
08/29/09 07:43 PM
dont run a rim screwless with tubes.
[Re: B1Fish540]
#453512
08/29/09 07:49 PM
08/29/09 07:49 PM
I got some new slicks and was wondering the same thing. Those are pretty cool rims, Chris! Who makes 'em? I'm always looking for different wheels, my car will just have some boring Pro Stars . I'm kinda stuck with Weld, because of the BS...and i need a street/strip wheel.
boring pro stars!! ![](/ubbthreads/images/graemlins/whistling.gif)
#453513
08/29/09 07:54 PM
08/29/09 07:54 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
boring pro stars!!
rut roh...i mean "the very popular" Pro Stars... and attractive! ![](/ubbthreads/images/graemlins/grin.gif)
[Re: 408Dust]
#453515
08/29/09 08:26 PM
08/29/09 08:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
To me it truly would be a couple of factors, if you run tubes... its a must... and second be be the tire pressure... if you run low tire pressure its not much holding the tire to the wheel and if you get sideways its easy to pop the bead free ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Cab_Burge]
#453517
08/30/09 07:45 AM
08/30/09 07:45 AM
Chris'sBarracuda
Arizona
The Wheels are Centerline Qualifier wheels. Back when I was a youngster I worked there and still am friends with the VP there. He took good care of me. ![](/ubbthreads/images/graemlins/thumbs.gif) I will be running tubeless. Have done it this way for years now. I have just seen so many cars WITHOUT screws lately, that I was afraid I was missing something. These are 14x32 stiff sidewall for Super Class racing. Gecker always had me put 16 screws per side-32 per wheel. I only put 12 on my last set. ![](/ubbthreads/images/graemlins/biggrin.gif) But what He has taught me about the number of screws in the wheel.... When the tire wrinkles, it will put as many wrinkles as there are screws... Therefore, the more screws, the more wrinkles---but they are smaller...And fewer screws mean less wrinkles and larger.. ![](/ubbthreads/images/graemlins/shruggy.gif) In this picture I'm posting you can see what I mean. The wrap of the tire starts at the screw, and travels outward. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) So.. If more screws are used and the wrap up is tighter, will the tire be stiffer? ![](/ubbthreads/images/graemlins/confused.gif) These are some of the questions I have floating around.. ![](/ubbthreads/images/graemlins/runaway.gif) Chris.. ![](/ubbthreads/images/graemlins/scope.gif)
#453518
08/30/09 11:36 AM
08/30/09 11:36 AM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
When the tire wrinkles, it will put as many wrinkles as there are screws... Therefore, the more screws, the more wrinkles---but they are smaller... So.. If more screws are used and the wrap up is tighter, will the tire be stiffer? ![](/ubbthreads/images/graemlins/confused.gif)
We did testing a few years back and on a big tire car with lots of torque that is correct as the smaller wrinkles help maintain the tire shape and contact patch. I don't think you will see that as much on smaller tire, higher pressure, lower powered cars.
[Re: johnnyrotten]
#453520
08/30/09 09:34 PM
08/30/09 09:34 PM
Chris'sBarracuda
Arizona
You need to tighten the screw in the drivers seat!
But what if that was YOU...![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
BTW Brian took my front clip last night to fix it.![](/ubbthreads/images/graemlins/thumbs.gif)
Chris.. ![](/ubbthreads/images/graemlins/haha.gif)
