What RPM to you set 2 step at?
#453309
08/29/09 12:42 PM
08/29/09 12:42 PM
Posts: 189 Coon Rapids, Minn.
MW Racecraft
Coon Rapids, Minn.
What RPM's are people using for the 2 step? Do you set rpms at max torque or just keep adding rpm until 60ft slows down? 3200lb 73 Duster 610 torque at 4800 604hp 5600 400ci Auto w/ cal-tracs 4:56 gear w/29.5 tire Thanks Mike
Re: What RPM to you set 2 step at?
[Re: MW Racecraft]
#453310
08/29/09 01:01 PM
08/29/09 01:01 PM
Posts: 10,038 MN
JERICOGTX
MN
Have mine set at 5300. That is where it 60' the best.
Jeff
69 GTX
68 Road Runner
[Re: Dodgeman67]
#453312
08/29/09 01:06 PM
08/29/09 01:06 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
You're gonna have to do some testing. Higher rpm doesn't always mean quicker 60' or more consistent 60s. 3400 works for me.
[Re: dartman366]
#453316
08/29/09 06:20 PM
08/29/09 06:20 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
4800 is where I hook the best. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: MW Racecraft]
#453319
08/29/09 07:22 PM
08/29/09 07:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont use a chip for launch... I have a 3 step but no chip for launch.... 1 chip for the burnout and 1 for over rev... 5600 stall converter and I leave at 5600 rpm on the converter.... that gives me a 1.19 60'(best) normal is a 1.21 60'
[Re: MW Racecraft]
#453321
08/29/09 10:06 PM
08/29/09 10:06 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would run it as low as I can to save parts in the trans, and for consistency. I would start testing at 2600 to 2800 rpm and see if it will leave consistently there. No sense beating up parts if you don't have to.
[Re: gregsdart]
#453323
08/29/09 10:28 PM
08/29/09 10:28 PM
Posts: 2,070 Taylor, Michigan
1BadLiLCharger
Taylor, Michigan
Especially if it keeps you green.
