AFB tuning #453175
08/29/09 09:11 AM
08/29/09 09:11 AM
Wpg, Mb, Canada
six-barrel Offline OP
Wpg, Mb, Canada
Since the Carter AFB "Street and strip" kits are no longer available, will the Edelbrock Performer or Thunder series tuning kits work?
Second question, right now:
Primary jet is 89
Secondary is 95
rods are 66/52
I'm way too rich, best guess how much smaller I need to go to get closer, AFR is at 11. AFR is consistent across the rpm range.
Engine specs:
486 CI Hemi (4.15 stroke)
stock heads (cleaned up), intake and carbs
Re: AFB tuning [Re: six-barrel] #453176
08/29/09 10:53 AM
08/29/09 10:53 AM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
bump
Re: AFB tuning [Re: six-barrel] #453177
08/29/09 12:44 PM
08/29/09 12:44 PM
Primary jet is 89
Secondary is 95
rods are 66/52
Engine specs:
You can change the rod to a 71-47, 1 73-52 or change the primary jet to a 86. are you sure the jets are in the proper location? Usually AFBs came with larger primary jets than the secoandary jets due to the metering rod being in the primary jet The Edelbrock jets and metering rods work fine in the AFB, make sure the rods you are using are the two step ones and not the three step ones that come with the AVS and some of the AFBs that used the raise step front jets
Re: AFB tuning [Re: Cab_Burge] #453178
08/29/09 02:49 PM
08/29/09 02:49 PM
Primary jet is 89
Secondary is 95
rods are 66/52
Engine specs:
with Cab,
something is wrong, that is aweful lean jetting sequence.
primary is always richer out of the box
now the problem going to a leaner jet with those 7147 rods, i bet your going to have a wicked bog, i believe your going to choke the primaries with that lean of a metering rod causing a serious lean condition off idle. how do i know.
remember the front section is the primary side and rear is the secondary section.
Re: AFB tuning #453179
08/29/09 10:37 PM
08/29/09 10:37 PM
Wpg, Mb, Canada
Wpg, Mb, Canada
bump
Re: AFB tuning [Re: six-barrel] #453180
08/29/09 11:54 PM
08/29/09 11:54 PM
Often overlooked is the metering rod springs, depending on amount of vacuum they might be raising early...This would be where I start.
Re: AFB tuning #453181
08/30/09 07:13 AM
08/30/09 07:13 AM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
What are the carb #'s? Your jetting is backasswards. Dave
Re: AFB tuning [Re: quickd100] #453182
08/30/09 10:28 AM
08/30/09 10:28 AM
Wpg, Mb, Canada
Wpg, Mb, Canada
4343 and 4139
Re: AFB tuning [Re: six-barrel] #453183
08/30/09 11:11 AM
08/30/09 11:11 AM
nielsville, minn.
Q
Q
nielsville, minn.
OK, 4343 is the rear carb for a 66/67 hemi, the 4139 is the frt carb. The factory jetting is as follows;
rear carb, (4343)primary jets, .089, secondary jets, .092(pump side) and .077(passenger side)
Metering rods, 16-543, (.069x.054) (pump side) and 16-544,(.071x.058) (passengerside)
front carb (4139) primary jets .089, secondary jets, .107 (pump side) and .089 (passenger side)
Metering rods, 16-136,(.071x.061)
The old MP recs for general hp use and racing are;
Front carb
left primary.083, right primary .101
left secndary.101, right secondary.101
Rod WOS .055
Rear carb
left primary.101 right primary .101
left secondary .101 right secondary .083
Rod WOS .055
Hope this helps, Dave
Re: AFB tuning [Re: six-barrel] #453184
08/30/09 11:13 AM
08/30/09 11:13 AM
Manitoba, Canada
liteweight Offline
liteweight  Offline
Manitoba, Canada
GoodDay Gentlemen, It's been about a year since I've been on this forum,but I see this post needs some explanation,since I'm the one that built the engine for sixbarrel including the jetting of it. You guys are correct in stating when you look at the jetting numbers THEMSELVES,the larger jets should be in the primary sides & the smaller ones in the secondary's.This is because of the area that the metering rods occupy.This is how all AFB & AVS's are "OUT OF THE BOX".Sometimes tho, a person needs to look outside the box.
The key here is the area between the metering rod & the jet itself.Take for example if you have a primary jet of 89 & you install a metering rod with dimensions of .066 on the cruise side & .052 on the enrichment side,you will have a much larger area for the fuel to flow than if you use a metering rod with dimensions of lets say .071 on the cruise side & .058 on the enrichment side.
So,when you look at the big picture,it doesn't matter what size jet is in the primary side ,it's the relationship of the area around the jet that is what gives you your actual delivered amount of fuel.
I have jetted it a little rich for a reason,to get it in the ballpark,& I'd rather be a little rich than lean. The fine tuning will come as we get more info.The metering rod springs will be the last to science out,after the jetting is correct.
Liteweight
68 Hurst LO Hemi Dart 70 hemicuda 4 spd. R code owned since 76 70 GTX 4 spd. 21,000 orig. miles 55 Ford F100 chopped,slammed,bagged & supercharged 96 Ram 2500 4X4 Twin turbo'd Cummins 550hp 1200 ft. lbs tow vehicle
Re: AFB tuning [Re: liteweight] #453185
08/30/09 12:17 PM
08/30/09 12:17 PM
Wpg, Mb, Canada
Wpg, Mb, Canada
Daryl is correct
What I'm looking for is how much less area (larger rod/smaller jet) to move the afr up 1.5 point.
Since I need to source rods and jets I'd like to purchase close to what I need based on fellow moparts members opinions, right now doing the math my cruise is at (89-66=23) and power is at (89-52=37). What do I shoot for in size 21/34. So how much a smaller area equates to an AFR increase of 1.5
Just trying to figure out where to start when purchasing rods and jets.
Re: AFB tuning [Re: six-barrel] #453186
08/30/09 01:26 PM
08/30/09 01:26 PM
nielsville, minn.
Q
Q
nielsville, minn.
If you're at 11/1 right now you'll need to lean things down by 13.6%. Calculate the area of your jet and rod combo and reduce the area by that much should get you there.Dave
Re: AFB tuning [Re: quickd100] #453187
08/30/09 03:22 PM
08/30/09 03:22 PM
Wpg, Mb, Canada
Wpg, Mb, Canada
Thanks, thats what I was looking for.
