Re: AFB tuning
[Re: six-barrel]
#453177
08/29/09 12:44 PM
08/29/09 12:44 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
Since the Carter AFB "Street and strip" kits are no longer available, will the Edelbrock Performer or Thunder series tuning kits work?
Second question, right now:
Primary jet is 89 Secondary is 95 rods are 66/52
I'm way too rich, best guess how much smaller I need to go to get closer, AFR is at 11. AFR is consistent across the rpm range.
Engine specs: 486 CI Hemi (4.15 stroke) stock heads (cleaned up), intake and carbs
You can change the rod to a 71-47, 1 73-52 or change the primary jet to a 86. are you sure the jets are in the proper location? Usually AFBs came with larger primary jets than the secoandary jets due to the metering rod being in the primary jet The Edelbrock jets and metering rods work fine in the AFB, make sure the rods you are using are the two step ones and not the three step ones that come with the AVS and some of the AFBs that used the raise step front jets
Re: AFB tuning
[Re: Cab_Burge]
#453178
08/29/09 02:49 PM
08/29/09 02:49 PM
with Cab, something is wrong, that is aweful lean jetting sequence. primary is always richer out of the box now the problem going to a leaner jet with those 7147 rods, i bet your going to have a wicked bog, i believe your going to choke the primaries with that lean of a metering rod causing a serious lean condition off idle. how do i know. remember the front section is the primary side and rear is the secondary section.
Re: AFB tuning
[Re: six-barrel]
#453180
08/29/09 11:54 PM
08/29/09 11:54 PM
Often overlooked is the metering rod springs, depending on amount of vacuum they might be raising early...This would be where I start.
Re: AFB tuning
[Re: six-barrel]
#453183
08/30/09 11:11 AM
08/30/09 11:11 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
OK, 4343 is the rear carb for a 66/67 hemi, the 4139 is the frt carb. The factory jetting is as follows; rear carb, (4343)primary jets, .089, secondary jets, .092(pump side) and .077(passenger side) Metering rods, 16-543, (.069x.054) (pump side) and 16-544,(.071x.058) (passengerside) front carb (4139) primary jets .089, secondary jets, .107 (pump side) and .089 (passenger side) Metering rods, 16-136,(.071x.061) The old MP recs for general hp use and racing are; Front carb left primary.083, right primary .101 left secndary.101, right secondary.101 Rod WOS .055 Rear carb left primary.101 right primary .101 left secondary .101 right secondary .083 Rod WOS .055 Hope this helps, Dave
Re: AFB tuning
[Re: six-barrel]
#453184
08/30/09 11:13 AM
08/30/09 11:13 AM
Posts: 290 Manitoba, Canada
liteweight
Manitoba, Canada
GoodDay Gentlemen, It's been about a year since I've been on this forum,but I see this post needs some explanation,since I'm the one that built the engine for sixbarrel including the jetting of it. You guys are correct in stating when you look at the jetting numbers THEMSELVES,the larger jets should be in the primary sides & the smaller ones in the secondary's.This is because of the area that the metering rods occupy.This is how all AFB & AVS's are "OUT OF THE BOX".Sometimes tho, a person needs to look outside the box. The key here is the area between the metering rod & the jet itself.Take for example if you have a primary jet of 89 & you install a metering rod with dimensions of .066 on the cruise side & .052 on the enrichment side,you will have a much larger area for the fuel to flow than if you use a metering rod with dimensions of lets say .071 on the cruise side & .058 on the enrichment side. So,when you look at the big picture,it doesn't matter what size jet is in the primary side ,it's the relationship of the area around the jet that is what gives you your actual delivered amount of fuel. I have jetted it a little rich for a reason,to get it in the ballpark,& I'd rather be a little rich than lean. The fine tuning will come as we get more info.The metering rod springs will be the last to science out,after the jetting is correct.
Liteweight
68 Hurst LO Hemi Dart
70 hemicuda 4 spd. R code owned since 76
70 GTX 4 spd. 21,000 orig. miles
55 Ford F100 chopped,slammed,bagged & supercharged
96 Ram 2500 4X4 Twin turbo'd Cummins 550hp 1200 ft. lbs tow vehicle
