Holley 950 HP Info #453154
08/29/09 08:53 AM
08/29/09 08:53 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I've got a used Holley 950 HP on my 440 and i cant find any info as regards jet sizes, pump cams and power valves fitted when bought new. I've looked through holley's site and cant find any info.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Holley 950 HP Info [Re: deaks] #453155
08/29/09 08:55 AM
08/29/09 08:55 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Take the bowl off and see whats in there.... I just sold mine and it had 4.5 pv and 79/73 jets
Mopar Performance
Re: Holley 950 HP Info [Re: moparniac] #453156
08/29/09 08:59 AM
08/29/09 08:59 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Is that what yours came with, there are 2 numbers on top 6 and 5 but they aren't next to each other, does that mean it's a 6.5.
Mick
best 60ft 1.36
Re: Holley 950 HP Info [Re: deaks] #453157
08/29/09 09:13 AM
08/29/09 09:13 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Re: Holley 950 HP Info [Re: deaks] #453158
08/29/09 09:16 AM
08/29/09 09:16 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Mick
Yes.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Holley 950 HP Info [Re: Leigh] #453159
08/29/09 10:13 AM
08/29/09 10:13 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Page 17
looks like 78/78 with 6.5 PV's front and back
so delete the rear pv and go 78/86 or both pv's and go 86/86 Holley jetting is real close as shipped
Re: Holley 950 HP Info [Re: Dodgem] #453160
08/29/09 11:18 AM
08/29/09 11:18 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I've just pulled it apart and it's got 6.5 power valves back and front, 31 shooters, 82 prim jets and 84 mains, should i jet down to 78's again and work up from there.
Why do you suggest taking the pv's out?.
Mick
best 60ft 1.36
Re: Holley 950 HP Info [Re: deaks] #453161
08/29/09 11:44 AM
08/29/09 11:44 AM
NC
440Jim Offline
440Jim  Offline
NC
I used to run a 950HP list 80496-1 and this is how it came:
78/78 jets
6.5/6.5 power valves
31/31 squirters
72/32 air bleeds
But I ran it without a power valve in the rear (plugged) and 78/86 jets. 35/37 squirters.
Re: Holley 950 HP Info [Re: deaks] #453162
08/29/09 11:46 AM
08/29/09 11:46 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Mick
Yes most people way over jet their carbs. stock jetting is real close and aluminum heads like less sometimes then add your 11 to 1 compression and your right back to stock. Rich is slow!
Re: Holley 950 HP Info [Re: Dodgem] #453163
08/29/09 01:14 PM
08/29/09 01:14 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Why did you take the pv out and what motor was this on.
Mick
best 60ft 1.36
Re: Holley 950 HP Info [Re: deaks] #453164
08/29/09 03:24 PM
08/29/09 03:24 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
For the moment i've swapped the jets for 78 prim and 79 secs which is as near to stock that i can achieve with the jets i have available.
I'm taking the car out tomorrow, i'm also going to try unbolting my dynaflows and try the 3.5x18" collectors i've got.
Mick
best 60ft 1.36
Re: Holley 950 HP Info [Re: deaks] #453165
08/29/09 05:37 PM
08/29/09 05:37 PM
SWEET HOME ALABAMA
I
ITSDUSTA416 Offline
ITSDUSTA416  Offline
I
SWEET HOME ALABAMA
My 950hp came 78prim and 79sec I removed the power valve in the rear and jetted up to 87's with jet extensions.
If your car leaves the line fast the gas will rush to the back of the fuel bowl and the fuel will not flow through the power valve.
71 DUSTER 416 ET 6.33 @ 107 1.33 60FT
