Fuel return line
#452983
08/29/09 12:43 AM
08/29/09 12:43 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I'm mapping out my fuel system so I can figure out what fittings and how much line I need. I am running two holley black fuel pumps and I'd like to run a return line instead of dead heading the system. When running a return line do you put the regulator after the carb to hold the fuel back? If you put the regulator in front of the carb the fuel will just flow right by the carb back to the cell right? I've always used a holley blue and dead headed, so I'm new to the return line set up Thanks for the help
Re: Fuel return line
[Re: DemonDust]
#452984
08/29/09 12:55 AM
08/29/09 12:55 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
mine is after the fuel log
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: DemonDust]
#452987
08/29/09 02:18 AM
08/29/09 02:18 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
Call Holley Tech and ask them the proper way to run one on thier regulator. I use Magnflow pumps with BG regulators now and the return line is from the pump to the cell, not from the front of the car I called Product Engineering on their regulator and they said to plug it(the return port) off if I wanted to use the Magnaflow pump
[Re: G_bob]
#452989
08/29/09 04:48 PM
08/29/09 04:48 PM
I use a mallory 250 pump and RobbMc return style regulator. With this system, the return line goes from the regulator back to the tank.
G BOB wheres your return ,i dont see it, heres my product engineering return system with -8 AN line back to the fuel cell.
#452990
08/29/09 04:49 PM
08/29/09 04:49 PM
another shot, i like my regulator in front of my carbs for the g force.they recommend 12" in front.
[Re: hemi-itis]
#452993
08/29/09 09:00 PM
08/29/09 09:00 PM
What are those 2 little lines off the splitter?? Looks like brake lines
those high and low port return lines with different size jets going back to the cell from the y block.
#452994
08/29/09 10:56 PM
08/29/09 10:56 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
Fuel feed and return lines are on the other side of the inner fender.
