Fuel return line #452983
08/29/09 12:43 AM
08/29/09 12:43 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I'm mapping out my fuel system so I can figure out what fittings and how much line I need.
I am running two holley black fuel pumps and I'd like to run a return line instead of dead heading the system. When running a return line do you put the regulator after the carb to hold the fuel back? If you put the regulator in front of the carb the fuel will just flow right by the carb back to the cell right?
I've always used a holley blue and dead headed, so I'm new to the return line set up
Thanks for the help
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Fuel return line [Re: DemonDust] #452984
08/29/09 12:55 AM
08/29/09 12:55 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
mine is after the fuel log
Re: Fuel return line [Re: DemonDust] #452985
08/29/09 01:53 AM
08/29/09 01:53 AM
The return line on a electronic fuel injection is from the regulator which is after the injectors so it will maintain the pressure on the injectors and release the pressure as needed. On a carburetor return line system it probally (I have not run a return line system from the front yet) has to have the return line from the return style regulator, I have a Product Engineering 4 port returm style regulator and it has a seperate port on the regulator for the return line
Re: Fuel return line [Re: Cab_Burge] #452986
08/29/09 02:02 AM
08/29/09 02:02 AM
Menomonee Falls
Menomonee Falls
I was looking at using one of the holley high flow regulators. So this would be placed after the carb right? The fuel log for my carb has the return off of it.
SDG Motorsports
Re: Fuel return line [Re: DemonDust] #452987
08/29/09 02:18 AM
08/29/09 02:18 AM
Call Holley Tech and ask them the proper way to run one on thier regulator. I use Magnflow pumps with BG regulators now and the return line is from the pump to the cell, not from the front of the car I called Product Engineering on their regulator and they said to plug it(the return port) off if I wanted to use the Magnaflow pump
Re: Fuel return line [Re: Cab_Burge] #452988
08/29/09 09:59 AM
08/29/09 09:59 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
I use a mallory 250 pump and RobbMc return style regulator. With this system, the return line goes from the regulator back to the tank.
Re: Fuel return line [Re: G_bob] #452989
08/29/09 04:48 PM
08/29/09 04:48 PM
G BOB wheres your return ,i dont see it, heres my product engineering return system with -8 AN line back to the fuel cell.
Re: Fuel return line #452990
08/29/09 04:49 PM
08/29/09 04:49 PM
another shot, i like my regulator in front of my carbs for the g force.they recommend 12" in front.
Re: Fuel return line #452991
08/29/09 07:59 PM
08/29/09 07:59 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What are those 2 little lines off the splitter?? Looks like brake lines
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Fuel return line [Re: DemonDust] #452992
08/29/09 08:11 PM
08/29/09 08:11 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Fuel return line [Re: hemi-itis] #452993
08/29/09 09:00 PM
08/29/09 09:00 PM
those high and low port return lines with different size jets going back to the cell from the y block.
Re: Fuel return line #452994
08/29/09 10:56 PM
08/29/09 10:56 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Fuel feed and return lines are on the other side of the inner fender.
