69 charger console shift plate? #452936
08/28/09 11:46 PM
08/28/09 11:46 PM
o'fallon, MO
Brian_E Offline OP
Brian_E  Offline OP
o'fallon, MO
anyone know what goes in the automatic shift console plate so you cannot see down inside to the shift linkage? i never had mine so dont know. thanks
Re: 69 charger console shift plate? [Re: Brian_E] #452937
08/29/09 01:36 AM
08/29/09 01:36 AM
There is a black plastic strip with a hole for the shifter handle to fit through. The plastic stripfits into a channel on the bottom side of the console plate. These are available aftermarket through be&a and other places.
Re: 69 charger console shift plate? [Re: ] #452938
08/29/09 06:55 AM
08/29/09 06:55 AM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
1MYTGTX
Re: 69 charger console shift plate? [Re: 1MYTGTX] #452939
08/30/09 01:12 AM
08/30/09 01:12 AM
o'fallon, MO
Brian_E Offline OP
Brian_E  Offline OP
o'fallon, MO
man u are hooking me up with my missing info. never had support on here like this, usually noone ever has an answer, thanks so much guys!!!
